July 2, 20179 yr Long shot, but just in case it helps someone, Herts police are looking to reunite recovered stolen goods with their rightful owners. Full story here: http://www.hertsad.co.uk/news/power-tools-stole-from-vans-hertfordshire-1-5086989
July 2, 20179 yr All of them are mine. So how do I prove it? I don't know how long I been putting off photographing all the serial numbers on my tools. This is the nudge I need to get the job started. Hmm, and I was stuck for something to do today, I really was. Thanks @Crofter Ian
July 2, 20179 yr Certainly worth doing. I know from experience how difficult it is to return property where there is no identifying information. Serial numbers make that task so much easier.
July 2, 20179 yr There was a spate of van theft up here 2 years ago. I mentioned it at the time. 3 of the vans belonging to the builders that built my shell got broken into the same night outside their houses in the same village. The investigating police were certain it was a gang from "down south" targeting villages just off the A9 starting at the north and working their way down overnight. I doubt it was this gang though.
July 2, 20179 yr if you want to make sure your property is identified there are several well known methods checked by the police. Any large plant is on a section of the PNC so your diggers should be registered to you when you buy them. Small plant can go on one of the national registers for free such as TER Mark you tools and record numbers as stated above. However a lot of forces only put the serial number on local systems so if stolen in say Humberside and found in Berkshire there would be no record. Use something like smart water. This is national and all forces check for it these days. A lot of forces do free marking days or even give out free smart water kits. Often best is to engrave with postcode if you can as an area of the tool filed off should raise suspicion.
March 22, 20197 yr After getting totally wiped out in Aug 2017, I made a commitment to spend money on security each time I bought new tools. Just bought a couple new Makita bits and as my lock up is like fort knox I thinking to mark all my tools with SmartWater or SelectDNA Anyone have a preference on which system is superior? Both packs cost £50, SmartWater marking is guaranteed for 5 years but I'm doubtful it would last that long on tools that get a beating.
