ProDave Posted November 9, 2022 Posted November 9, 2022 2 hours ago, Mr Punter said: But if you cut it back so it finishes behind the plinth it won't be seen. Just mark the cut level with the bottom of the doors. Be you have to make 2 cuts. The vertical cut, yes, hidden behind the plinth. But the horizontal cut in line with the top of the kick board, you have to do perfectly without chipping the board finish on either side, and then you need to protect the raw cut edge of the board somehow.
Mr Punter Posted November 9, 2022 Posted November 9, 2022 Apparently the trick to cut MFC without chipping is to do a very shallow cut with your circular saw using a blade with lots of teeth, then increase to full depth. You need to clamp a fence to the panel. The vertical cut can be done with a pocket squirrel.
Radian Posted November 9, 2022 Posted November 9, 2022 47 minutes ago, Mr Punter said: pocket squirrel I just googled that and there were lots of cute pictures. Nothing that would make a clean vertical cut without lots of training though.
Mr Punter Posted November 9, 2022 Posted November 9, 2022 11 minutes ago, Radian said: I just googled that and there were lots of cute pictures. Nothing that would make a clean vertical cut without lots of training though. I just use it to describe any carpentry work that looks like it has been randomly chewed away.
Radian Posted November 10, 2022 Posted November 10, 2022 1 hour ago, Mr Punter said: I just use it to describe any carpentry work that looks like it has been randomly chewed away. Ah, an untrained squirrel then.
