3 hours ago, Thorfun said:
hi all. thought i'd done with this thread but as i start fitting out the basement i realise that i could do with more opinions on a few things.
my cabinet is pretty full and i have very few relays free or channels left on my DMX 24V RGBW WhiteWing dimmer. As such i'm thinking about fitting the Loxone RGBW Tree Spots (recessed) in our music room.
Just wondering if anyone has an opinion on them apart from being expensive!
i've looked at using Voltus RGBW bulbs but they're over €50 each and when you take in to account the fittings as well it's not too much less than the Loxone spots and then i'd need relays to control them whereas the Loxone ones are simply tree controlled. so it's much easier and probably cheaper in the end!
the other thing is that i will probably use standard retractive switches to control the lights and so will need to run a separate Cat6a cable so i'm thinking it's not worth using Loxone Tree cable as i'd still have to run 2 x cables anyway. so i've got Cat6a leftover from the rest of the cabling and i was thinking of using that and running 1.5mm 2-core flex along with it. is that ok to do? would folk recommend running standard 1.5mm T&E even though i don't need the earth for 24V lighting? cost difference between the 2 isn't much but T&E is stiffer cable and harder to run.
just looking for opinions please. 🙂
What are your lighting requirements? To me basement with retractive switches sounds like basic GU10s would be fine... But it seems like RGBW is non negotiable?
If so yeah the Loxone offerings are going to give all the lighting you need without any more panel DIN space needed. I forgot, you have ps&b or something else with plenty 24V power headroom already in there?
Personally I'd got CAT6a + T&E to each fitting as it gives you future options, and every sparky carries infinite T&E and knows how to handle it. (E.g. My sparky complained anything smaller was too "snappy" when pulling through voids)
But if doing it yourself year 2 core 1.5mm will be a bit easier to work at each fitting.
different coloured lighting can affect people's emotions, e.g. blue to help focus, red to calm etc. so when recording being able to change the colour of light can help someone if they're struggling with getting something recorded. as such, I would like RGBW somewhere in there. LED strips would work but the lack of drivers/space in the cabinet precludes that unless I want to do a massive overhaul already and add a LXN-2 underneath the existing cab (which I don't!).
I have a PS&B and the current usage on most of the fuses is nowhere near the max so I can easily run some 24V spots. I also still have one fuse unused so have plenty of headroom there for me. which is why I thought the expensive Loxone tree RGBW spot route would just be easy for me as a quick solution.
I'm leaning towards the 2-core 1.5mm for ease of use again. the cost difference is negligible so it'll probably come down to my own laziness and an easy life will win over. it's just there's the voice at the back of my head going "what if you want to put 230V lights in there later and need an earth?". trying to run that later would be a pain! so maybe I do just run normal T&E.
have you used the Loxone RGBW spots? wondering if their claims for the smooth dimming are true. also I found some posts on the Loxone forum that mentions the spots WW were only 38° spread and not very bright, but I think they were the Gen1 spots and someone else responded with that wasn't their experience! so, again, just looking if anyone has used them and can give a review.
If you'd rather LED strip have a look at the dimmer compact
https://shop.loxone.com/enuk/rgbw-24v-compact-dimmer-tree.html
(Or Air)
They're electrically identical to the din rail variant but skinny enough to post through a down light cut out or similar so you can dot them around near the strip. But being low voltage input you still need to run chunky cable to them to avoid voltage drop.
I've only briefly used the Loxone spots during their training, not enough to get an opinion on their effectiveness in domestic setting. But their office is done with them pretty much exclusively and seemed okay enough (I was only there in daylight and using office like moods really).
(Or Air)
damn! something else to consider! 🤣
was just discussing it with swmbo (well not so much discussing more using her as a sounding board) and I realised that I am having some 230V wall sconces for additional lighting so I might as well just run T&E for the power requirements and a single Cat6A cable for the control requirements. so will only be 3 cables which isn't too onerous.
now you've thrown a spanner in the works with the dimmer compact I'll have another think about the lighting design.
Ok but some T&E will be switched mains circuits and other have 24V permanent power so the only saving is needing a single cable drum for them both. You still need to manage the topology in a way that makes sense per fitting.
Put another way: I don't know of any Loxone tree lighting devices that can run straight of mains. Unlike say DALI RGBW drivers which typically do.
yeah. sorry. i don't think i explained myself very well!
1 x 1.5mm T&E cable for the 230V lights going to a spare relay completely separate from the 24V/tree stuff
1 x 1.5mm T&E cable from my Wago terminal blocks 24V block to the 24V on the Loxone tree spots
1 x Cat6A cable with green/green&white to the tree of the spots and a.n.other pair to the retractive switches with the orange/orange&white going to the 24V of the retractive switches or presence sensors etc.
make sense? or am i talking rubbish as usual? 🤣
We used 5-core in most places for lighting unless we knew that the lighting circuit was definitely going to be i) single-color ii) use a cabinet-based dimmer.  Wtih 5-cores we could then:
- power RGBW or tunable strips from with central LED driver,
- send 230v + DALI to remote drivers (all our downlights and some other fittings are DALI)
- send dimmed 230v
- could even send 24v + loxone tree if needed. (albeit overkill core area)
- send dimmed 230v
Yes, if you're doing DALI this makes total sense. I used 5-core 1.5mm for all my RGBW LED strip as I had all dimmers centrally, but not sure I'd have bothered if I was doing drivers local to the fitting, but if it's the cable you have to hand then yeah why not.
Not Tree over 5-core flex would not be advised as it's not twisted pair (nor screened). It'll probably work fine if the lengths are not too long and its not a heavily loaded branch, but could create headaches. Even I would probably reach for a wireless solution like Air or shelly/wifi before resorting to that.
80% was DALI or LED, and it was easier for electricians to use same cable everywhere and avoid any mix-ups.  If you drivers are local to fitting you going to need more than twin-earth anyway, unless control is wireless or you have a seperate dali/dmx/tree/control cable.
One example of where having this 5-core in place was handy was bedside lamps.  We ended up choosing some wall lamps that have a wall light an a reading light, by using 4 cores were were able to give it a permannt live for the reading light (locally switched) and have the wall light on a loxone-controlled dimmer. We couldn't have done this otherwise once everything was boarded.  It also meants that, when we finally source and install pendants we have option to use mains dimmed or DALI etc.
You're right re: tree via 5-core.   The scenario I was thinking about was a pendant in the hall, where we only decided later to use the Loxone pendant.  What we did in this case was use the 2 cores (of the pre-wired 5-core) to supply 24v to the pendant, and then brought tree from the closest light switch.
  • 7 months later...
8 hours ago, Johnnyire said:
Where did you purchase your patch panel and equipment inside it? Thanks.
I bought mine from various places. Decided on what I wanted to use then scoured the internet for the best prices. I’m pretty sure I put my spreadsheet (or a screenshot of it) on this thread somewhere!!
Do you mean the Loxone cabinet or the comms cabinet? The Loxone cabinet was from @Rob99on here. The comms cabinet, shelves, patch panel, and PDU was from Cable Monkey. I have abother one in the garage.  All the other kit was from various places or I already had.
I misunderstood too! Thought they meant the connector blocks in the Loxone cabinet. 🤦‍♂️
I got my patch panels from cablemonkey as well. Were the cheapest place I found.
my server rack cabinet came from broadbandbuyer.
These cable monkey cabinets are on the dearer side but they are very well made. I bought a previous one from Amazon you had to assemble and it was made from tin foil so returned it.
The issue I had is I couldn’t fit a full depth cabinet as the MVHR unit is in the way. This is a 320mm deep cabinet but it only has 230mm of working depth inside from the mounting rails to the back of the panel which made cabling it hard work with CAT6a cable as it’s a bit inflexible. If also doesn’t have any inbuilt cable routing that some of the bigger cabinets have. It’s not as tidy inside as I like. At some point I’ll tidy it up. Winter weekend job.
Edited by Kelvin
Shame about the lack of space. I managed to shoehorn a 600(d) x 800(w) 36u tower in my comms room. So won’t take a full server but I can put together my own server in a shallow case should I require it.
Edited by Thorfun
I have a Synology NAS but it’s in the office rather than in there as it’s too tall. I couldn’t fit the NVR in the cabinet either so it’s sitting on top of it. All the networking equipment is quite small so it is all in there. Recently upgraded my TP-Link router to a Unifi Cloud Gateway Ultra which is very compact given what it can do.
I’ve no doubt my 36U cabinet is complete overkill! But I do like the space I have in it for “future expansion“ 😂
On 18/05/2024 at 09:02, Kelvin said:
The Audioserver and in-ceiling speakers sound much better than I was expecting too
hey @Kelvin! i'm starting to think about adding my audioserver to my setup. Can i ask what in-ceiling speakers you used? And also what PSU are you using to power the audioserver and stereo extensions?
and a generic question to any knowledgable Loxone folk about Tree turbo. The audioserver datasheet says that Tree Turbo and Tree are not compatible. so i presume that the AudioServer doesn't connect to the miniserver by tree but accesses it via the network? the datasheet also says to use 1.5mm cable for the power for the audioserver/Tree turbo. but running the power and 24V through a cable size calculator it looks like 1mm would suffice.
i have an audioserver and 4 stereo extensions but will probably add another couple of extensions to make it 6 in total. i can easily have a spare power outlet from my Powersupply and backup unit so that would be able to supply 240W of power but my audioserver will be in my network rack which will result in about a 5m length of wire from PSUB to the audioserver so i'm thinking about getting a standalone PSU just for the audio server and adding it to the DIN rail in the network cab as over 5m i'd need a 2.5mm cable. still doable though!
I used a mixture:
A single Focal ICW8 for the master bedroom
Single Bowers & Wilkins CCM362 for each of the other bedrooms and a pair of the same for the open plan area and 4 B&W CCM382s for the cinema room.
All the speakers are either mounted inside a firehood or an acoustic box I made. This is important as without something the bass response can be quite poor.
Of the two speaker types the Focal has a much better mounting system as it has a separate frame that the speaker mounts into. The B&W speakers have clamps that turn then tighten against the back of the plasterboard. It works fine it’s just that the separate frame of the Focal is a better design.
My whole cabinet is powered from the Loxone PSU and backup.
Tree Turbo is IP based and allows for much higher data throughput than tree. It can be used with the Loxone master/client speakers which allows it to transmit audio over much greater distances. The Audioserver connects to the Miniserver via the LAN. I’ve found the Audioserver a bit flaky with its network connection. I had no end of grief when it was first installed using a temporary spare router. The main issue being that if I rebooted everything it would often not reconnect to the internet or if it did connect I couldn’t access its Web-UI even though it was working. When I swapped out that router for my TP-Link router (when we moved) I couldn’t get it to connect at all so wiped it and recommissioned it which seemed to improve matters. However it would still occasionally lose connection if I re-started the network requiring a few re-boots to get it to connect. I’ve since replaced the TP-Link router with a Unifi Cloud Gateway Ultra and it’s never done it with that and I can always connect to its Web-UI so seems resolved.
I'd imagine they're over specifying it as everyone does in audio. Gold plated connectors and all the rest of it.
It'll work fine on 1mm if you have to, but if you're running the power 5m between cabinets to the audioserver I'd be inclined to  cable anyway, it's not going to make a measurable difference to the project cost.
Interesting experience @Kelvin with the TP link. I've only ever used audioserver with unifo router (3 installations) so can't comment other than confirm I never saw those symptoms. The main issue I've dealt with is flakiness with AirPlay discovery and control. But I don't use that myself
