Adsibob Posted November 4, 2022 Share Posted November 4, 2022 I need to carry some 50 wheel barrow's worth of soil and MOT down the side alley of my house. At one point, there is a 28cm drop and i need a decent ramp that will carry the weight of one wheel barrow. I was just going to use some spare plyboard (two sheets, doubled up, with one overlapping the other to create a slight diagonal, supported by some sand bags underneath), but it turns out I don't have any left and given the cost of ply I thought I may as well buy a proper ramp as it would have uses in the future. Was flabbergasted that Screwfix didn't have anything for less than £250. Found this on amazon which is closer to my budget: https://www.amazon.co.uk/Black-Range-B5249-Folding-Motorcycle/dp/B076CM3NPS/ref=sr_1_12?crid=1RXLPZKDT9Z4H&keywords=ramp&qid=1667576923&qu=eyJxc2MiOiI2LjgwIiwicXNhIjoiNi4wNCIsInFzcCI6IjUuMTAifQ%3D%3D&sprefix=ramp%2Caps%2C79&sr=8-12 Anyone think it will work, or will it be annoying that it only really holds the wheel barrow, with little space to walk on? Any better suggestions? Link to comment Share on other sites More sharing options...
markc Posted November 4, 2022 Share Posted November 4, 2022 Go with a couple of scaffold boards or whatever you have laying around. I have a motorbike ramp and the ends are too narrow so it rocks over easily Link to comment Share on other sites More sharing options...
ProDave Posted November 4, 2022 Share Posted November 4, 2022 +1 for scaffold boards. Support them at least mid span with anything that will fit, any old blocks of wood, pile of blocks, sand bags etc. I would want two side by side secured together somehow, one is just a little narrow for a barrow unless you are careful. Link to comment Share on other sites More sharing options...
Adsibob Posted November 4, 2022 Author Share Posted November 4, 2022 Thanks everyone. Hmmm, now I need to find some scaffold boards. Building works finished about 6 months ago... so not much left on site. Link to comment Share on other sites More sharing options...
SuperPav Posted November 4, 2022 Share Posted November 4, 2022 Where are you? I've got some steel and ally ramps, and some scaffold planks, but obviously this is only if you happen to be in a very short radius of my regular travel corridor! Link to comment Share on other sites More sharing options...
SimonD Posted November 4, 2022 Share Posted November 4, 2022 1 hour ago, Adsibob said: now I need to find some scaffold boards. Any decent diy shop will have them. And if you've got a local timber recycling centre they've usually got a good handful of the things knocking around. You'll be shocked that even a couple of scaffold boards from wickes will set you back £60 now - they were less than £14 each when I last bought some! Link to comment Share on other sites More sharing options...
