puntloos Posted October 23, 2022 Share Posted October 23, 2022 My current kitchen has 4 m2 worktop space (6800mm, 22 feet, 60 deep), which includes roughly 1 m2 space for hob and sink. (800 each) My new kitchen design has 2.64 m2 island (1000x2640) and 2.40 m2 normal worktop -> 5 m2, but 2 sinks, so let's say 3.5m2 left. (pic attached, worktop and sink marked in red) So in theory, yay, slightly more room, but in practice, I can imagine I don't want to leave stuff (used plates, pans etc) on the island, especially right now I'm looking at my current uncleaned kitchen and almost every inch of worktop has some random stuff on it. Should I try to increase worktop space in new kitchen? Or is it actually fine? One important fact is that a lot of my current worktop appliances - rice cooker, coffee maker, kettle, I was planning to insert inside a cupboard so that would increase space a bit more. Link to comment Share on other sites More sharing options...
ProDave Posted October 23, 2022 Share Posted October 23, 2022 Only 1M between main units and island will be too little if either has a dishwasher with a pull down door, you will curse as you empty it, you cannot get past the door to put stuff away. 1 Link to comment Share on other sites More sharing options...
puntloos Posted October 23, 2022 Author Share Posted October 23, 2022 3 hours ago, ProDave said: Only 1M between main units and island will be too little if either has a dishwasher with a pull down door, you will curse as you empty it, you cannot get past the door to put stuff away. Fair shout but indeed we've thought about that one. It's a bit of a compromise, but the dishwasher opens up right at the intersection (near the door), so should not be blocking too much. Link to comment Share on other sites More sharing options...
Conor Posted October 24, 2022 Share Posted October 24, 2022 I think it's enough. Our island is pretty much the same, didn't go for a prep sink though as wanted more wortop space. No regrets as main sink is right behind my prep area on the island Link to comment Share on other sites More sharing options...
Kelvin Posted October 24, 2022 Share Posted October 24, 2022 If you worktops are covered in stuff now the new kitchen will be the same. It might start out tidy because it’s new but if this is your habit then you’ll revert back to it. Increasing the worktop size will just give you more flat surface to leave stuff. Much better to introduce some better habits that keeps the area tidy. Link to comment Share on other sites More sharing options...
