GrantMcscott Posted October 21, 2022 Posted October 21, 2022 Just got a quote for rendering my new buid and it is £34,100 for about 150 sqm I know there is some complex bits and a lot of windows but though this sounded very expensive strip existing scaffolding. : supply and erect scaffolding. : cover all windows and doors . : bond all blockwork . : fix new render beads . : apply first coat adhesive render with anti crack fibre mesh. : supply and fix new render topcoat materials. : silicon seal all windows and joints on completion of works. : skip all building waste. QUOTE £34,100.
nod Posted October 21, 2022 Posted October 21, 2022 Ask him for a quote without scaffolding Sounds high
GrantMcscott Posted October 21, 2022 Author Posted October 21, 2022 I have my own Kwikstage scafolding here but he want to use his own it does not cover the whole house but enough to do the bits where he is rendering. I was expecting about betwenn £50 and £80 Sqm 5 minutes ago, nod said: Ask him for a quote without scaffolding Sounds high
nod Posted October 21, 2022 Posted October 21, 2022 (edited) 11 minutes ago, GrantMcscott said: I have my own Kwikstage scafolding here but he want to use his own it does not cover the whole house but enough to do the bits where he is rendering. I was expecting about betwenn £50 and £80 Sqm Most of my site work is around £55 m2 We obviously don’t get involved in scaffolding 150 m2 Should be a week Tops Edited October 21, 2022 by nod
GrantMcscott Posted October 21, 2022 Author Posted October 21, 2022 5 minutes ago, nod said: Most of my site work is around £55 m2 We obviously don’t get involved in scaffolding 150 m2 Should be a week Tops Thanks for that so it is well over the top 13 minutes ago, Mr Punter said: That sounds crazy. Get more quotes. yes that is what I thought just was making sure.
nod Posted October 21, 2022 Posted October 21, 2022 It is Put a drawing up of your house and Hopefully your not in London as the price would probably be cheap
Thedreamer Posted October 21, 2022 Posted October 21, 2022 1 hour ago, GrantMcscott said: Just got a quote for rendering my new buid and it is £34,100 for about 150 sqm I know there is some complex bits and a lot of windows but though this sounded very expensive strip existing scaffolding. : supply and erect scaffolding. : cover all windows and doors . : bond all blockwork . : fix new render beads . : apply first coat adhesive render with anti crack fibre mesh. : supply and fix new render topcoat materials. : silicon seal all windows and joints on completion of works. : skip all building waste. QUOTE £34,100. Do you have other quotes?
Chanmenie Posted October 21, 2022 Posted October 21, 2022 That seems high, I was recently quoted £7000 for my chalet bungalow approx 170m. EWI pro Silicone render 1
GrantMcscott Posted October 22, 2022 Author Posted October 22, 2022 20 hours ago, nod said: It is Put a drawing up of your house and Hopefully your not in London as the price would probably be cheap Scotland KA18 178450076_ELEVATIONSWITHFRONTENTRYRENDERED.pdf
nod Posted October 22, 2022 Posted October 22, 2022 There’s a bit of sheeting up But far from awkward If it’s concrete block I wouldn’t bother with a scratch coat Looks about a weeks work for a gang
GrantMcscott Posted October 22, 2022 Author Posted October 22, 2022 54 minutes ago, nod said: There’s a bit of sheeting up But far from awkward If it’s concrete block I wouldn’t bother with a scratch coat Looks about a weeks work for a gang Hi yes it is all block where it is getting rendered
nod Posted October 22, 2022 Posted October 22, 2022 It doesn’t need mesh and scratch coat It’s worth adding mesh above and below the windows But that can go on with the beads We tend to only use mesh on high suction blocks or roughcast Or if we want to bump the price up Just kidding 😁 So there’s a saving there Probably about a third 1
themucky1 Posted October 28, 2022 Posted October 28, 2022 On 21/10/2022 at 17:18, GrantMcscott said: Just got a quote for rendering my new buid and it is £34,100 for about 150 sqm I know there is some complex bits and a lot of windows but though this sounded very expensive strip existing scaffolding. : supply and erect scaffolding. : cover all windows and doors . : bond all blockwork . : fix new render beads . : apply first coat adhesive render with anti crack fibre mesh. : supply and fix new render topcoat materials. : silicon seal all windows and joints on completion of works. : skip all building waste. QUOTE £34,100. Depends what type of house it is, ie timber frame, sips or block?
GrantMcscott Posted October 28, 2022 Author Posted October 28, 2022 2 minutes ago, themucky1 said: Depends what type of house it is, ie timber frame, sips or block? Block
themucky1 Posted October 28, 2022 Posted October 28, 2022 On 21/10/2022 at 17:18, GrantMcscott said: Sorry didn’t see the drawings. That’s a high price even by my standards
