Rendering cost
GrantMcscott
Just got a quote for rendering my new buid and it is £34,100 for about 150 sqm I know there is some complex bits and a lot of windows but though this sounded very expensive
strip existing scaffolding.
: supply and erect scaffolding.
: cover all windows and doors .
: bond all blockwork .
: fix new render beads .
: apply first coat adhesive render with anti crack fibre mesh.
: supply and fix new render topcoat materials.
: silicon seal all windows and joints on completion of works.
: skip all building waste.
QUOTE £34,100.
I have my own Kwikstage scafolding here but he want to use his own it does not cover the whole house but enough to do the bits where he is rendering.
I was expecting about betwenn £50 and £80 Sqm
5 minutes ago, nod said:
Ask him for a quote without scaffolding
Sounds high
Most of my site work is around £55 m2
We obviously don’t get involved in scaffolding
150 m2 Should be a week Tops
Edited by nod
Thanks for that so it is well over the top
13 minutes ago, Mr Punter said:
That sounds crazy.
Get more quotes.
yes that is what I thought just was making sure.
QUOTE £34,100.
Do you have other quotes?
It doesn’t need mesh and scratch coat
It’s worth adding mesh above and below the windows But that can go on with the beads
We tend to only use mesh on high suction blocks or roughcast
Or if we want to bump the price up
Just kidding 😁
So there’s a saving there
Probably about a third
QUOTE £34,100.
Depends what type of house it is, ie timber frame, sips or block?
