Adam2 Posted October 8, 2022 Posted October 8, 2022 So, as soon as I comment that things are working well with our Cool Energy iVT-18 ASHP, I notice the control panel is showing an alarm code AL114. Not a very helpful message to describe it: "Power+ alarm:Power+ offline". I've tried the "IT solution" turn off leave a few mins and turn on - still the same. If anyone has seen this before or has suggestions please let me know as would be nice to try a few things before contacting them at Cool Energy as they seem not to be there at the mo.
Radian Posted October 8, 2022 Posted October 8, 2022 1 hour ago, Adam2 said: So, as soon as I comment that things are working well with our Cool Energy iVT-18 ASHP, I notice the control panel is showing an alarm code AL114 Your fault... You prodded the 'reality generator'. Sometimes chinese firmware copies over numbers like these. Variously AL114 has meant: Power+ alarm:Power+ offline (Carel) memory backup battery fault (Carel) Probe B2 alarm (Carel) room thermostat fault (Aermec) Power+ alarm: Drive connection alarm (EMAUX) Not much help I guess. 1
Adam2 Posted October 8, 2022 Author Posted October 8, 2022 So, I used the app to change to heating only (as it was stuck on hot water cylinder priority I guess) then turned off for 15 mins. Turned on and all OK on heating and no more alarm ! 🙂 Left that for a while to get the buffer up to temp then put back to heating + hot water and after a short time it switched to hot water and seems OK. So emergency over 🙂 Will try and find the cause but if happens again I guess try the same but this is the first occurrence since installed in March - though does probably coincide with the first cooler night (8 degrees). If I find a possible cause will share on here for others 1
dpmiller Posted October 8, 2022 Posted October 8, 2022 The inverter looks like it tripped off the bus. I've had mine do this if power cycled too rapidly, have you seen any mains dips? 1
Marvin Posted October 8, 2022 Posted October 8, 2022 Because the installation instructions discusses problems when the voltage drops, we had installed the next size cable up for the distance and ampage to reduce the risk of voltage drop and installed a type C RCBO 1
HughF Posted October 8, 2022 Posted October 8, 2022 Power+ alarm:Power+ offline The Power+ is the inverter/vfd that drives the compressor. It’s connected to the main Carel pCO control PCB via rs485/modbus. This error would imply that the Power+ hasn’t powered on properly, so isn’t responding to commands from the pCO. 1
Adam2 Posted October 10, 2022 Author Posted October 10, 2022 Very interesting, will see how this goes and if happens again look at cable size
