How would you finish round these windows?
Options put forward are stop the blocks at the height of the fascias so there’s a straight line across an clad in anthracite grey the rest of the way up.
Plastic fascia on the upper angles an couple of catnics and make super sized sills or a narrow lintel with a thin sill
continue the blocks up to the roof line in three ‘pillars’ then put anthracite fascia between the upper an lower windows and on the two remaining angles
Had also thought I could frame it out and put render board on the angled bits above windows and make thin blocks and stick them on kind of like you would with decarock but that still leaves the between upper n lower window to make something that will work
suggestions welcome and needed
Edited by Barryscotland
That’s a bit of a kerfuffle isn’t it. What do the drawings show?
I would have thought continuing the blocks up in pillars would look the best. And between the lower and upper windows but I guess that’s not do-able?
I see on the side window there’s a lintel that matches the blocks, or at least seems to. Is that not an option?
Edited by Russdl
Added some stuff
Drawings show decaroc with no sills,
drawings will be amended when we’re done
Problem is the depth between the lower and upper window is to much for just a sill unless it’s a monster, we could (I think) set a monster sized sill on a catnic lintel
We can make a lintel or sill to any size to match the blocks we’ve made
If you have the budget there are companies that make steels/lintels any shape you want. They also cut bricks to make slips and supply the lintels with them ready fitted. We have two windows that needed lintels shaped like this..  _n_  and got them made that way. You can't see any exposed steel anywhere.
Get your SE to specify some angles and SHS posts as lintels. The loads won’t be massive so the section sizes could be quite small. Alternatively get Keystone to design you something.
@Barryscotland
Barry that is looking good by the way.
Have done something like this before. I would go for a 150 x 90 x 10  thk angle section galvanized. You angle cut top and botton and put on a 6.0mm thk plate at the top and bottom . It's a structural "by inspection" issue per it's the detailing.
The main thing is to get the coursing right..that is the key so it looks good.. the rest is fairly simple but you need to make sure it is all tied back to the kit.. or it's dangerous.
If you get stuck PM me.
unfortunately there’s no budget left, that’s why we are making the ‘stone’ instead of decaroc or similar. Cement was reduced down to 50p a bag at BnQ and we had aggregate left over.
  • 7 months later...
This is how we ended up finishing it. Still need to make the date stone for the hole thats left and in hind sight should of bought some brown vents instead of using the whites we already had. Just need to build up the ground level now then roughcast the rest.
