Help - dpc insulation….
Devil_bri
I’ve googled the life out of this and can’t find the info I need, I’m sure it’s out there but I can’t find it….
I have the foundation in for a 7mx5m block garden room, with 100mm cavity. It falls under permitted development so no need for PP or BC.
I am about to get the footings put it then I will fill the floor with the usual hardcore, sand, DPM, 100mm insulation, anther sheet of the DPM and then 100mm concrete. Which layer of DPM do I need to tie in with the dpc on the walls, the bottom or top layer or both ?
thanks
thanks
Top one, technically you don’t need a dpm under the insulation unless you are using wool or some other absorbent insulation
If you want to be safe lap the DPM from below the kingspan. What harm can it do ? Double safe tape the top one up against the wall, It will make it easier to finish your concrete. I'm not sure where the trapped water is supposed to come from unless its raining.
