T&G P5 boards - short ends always on the joist?
Olf
I've drawn the layout and calculated number of boards assuming that because they are tongue & groove (and boneded with foaming glue) it does not matter where they meet.
However reading now advanced fitting guide it states: All short end joints should always fall on the centre of a secured joist including perimeter edges.
Is that the case in practice?
Of course in my refurb joist spacing appears to be random, if I was to follow that rule, instead of 3 boards per row (7m internal width, 3x2.4m boards should do it) I probably need another one for each row, if the previous 3 are chopped to match the joists. And is square edge sitting on the joist more rigid than suspended glued tongue & groove?
In practice, the boards are generally just laid wherever they fall. We’ve never had issues with movement on an unsupported end as long as glued well. Any squeaks/noises are generally down to not enough glue/nail missing joists.
Having said that, most of the joists we work on are 400cc.
Sounds like a plan: on landing (only 2 boards side by side) I'll add noggins under the joints.
In the rooms I will just go with the flow: with many neighbouring boards, each shifted by half width, they will hold the short ends from either side.
  • 2 weeks later...
Though I could not find that in builing regs, there is actually a nice chapter in NHBC standards.
It also mentions 'long edges at room perimeters should be fully supported on joists or noggings' - oh well, I've got 2 more rooms to improve :)
Though in my defence the existing floor (T&G planks) did not have that feature.
