So after demoloishing the old house I have a half-inch copper pipe in the gorund that I would like to rig to a temporary stand pipe.  Nothing fancy that has to be signed off by the water company, just a plastic pipe to a bib tap.
Being totally clueless about pipe sizes and fittings, what do I need to connect the half inch copper pipe to a few metres of plastic pipe (so that I can bury it to the boundary) and then a bib tap for the other end of the plastic pipe.
So I need the connector, the plastic pipe, and a bibtap. Which products do I need to do this?
You can get a copper to MDPE - or a universal transition joint, that gets you onto MDPE - see if you can blag a few meters of 25mm or something and just get a 25mm bib tap.
Remember inserts for the 25mm pipe.
That is it really.
Edited by Carrerahill
Which size, they all seem to be 15mm on the small end.
So would I need something like this too... https://www.screwfix.com/p/flomasta-compression-adapting-male-coupler-15mm-x/69358#product_additional_details_container
I used one of these to get me from 3/4" to 25mm
Plasson 77017 universal coupling 20-27 x 25mm | Wolseley
I was fretting about it for weeks as the 3/4" wasnt in the best state being buried under earth and rubble, bloomin amazing, they come with a range of input sizes so just pick t he one that suits the 1/2 inch pipe and make sure you clean and square up the 1/2" pipe before if not already done so.
How far do you need to extend it, if only a couple of metres then forget mdpe as you have to buy a 25m coil.
Just go and get a 3m length of hep pipe and a straight connector and a hep washing machine tap.
Will save you loads of cash and it’s all available from toolstation.
Assume this copper pipe still has its double check valve in place as you mustn't allow mains water to get contaminated.
