sneakyben Posted June 27, 2022 Posted June 27, 2022 (edited) Hi, I have a new extension... with only one real problem that I have not been able to fix... I am hoping some people here could help me with a solution to my issue, with our new extension... We have fitted 2x Two identical Velux windows... but they are not staying open the same amount... is this normal? How can we fix it? (or even get them open more?) [I am aware they wont ever open a lot, due to the shallow slope of the roof] Edited June 27, 2022 by sneakyben
Mr Punter Posted June 27, 2022 Posted June 27, 2022 They should open loads more than that. Pull harder on the handle.
sneakyben Posted June 27, 2022 Author Posted June 27, 2022 They do open more than that, but this is where they 'settle', after the handle is let go after pulling to fully open (i.e. there is no restriction to the opening)
ProDave Posted June 27, 2022 Posted June 27, 2022 Ours seem to have a lot more friction and wind permitting, stay at any angle you choose , even one that would let the rain in.
JamesP Posted June 27, 2022 Posted June 27, 2022 (edited) What pitch is the roof? It can have an effect on centre pivot windows. You could ask Velux if some stronger friction springs are available. Edited June 27, 2022 by JamesP
sneakyben Posted June 27, 2022 Author Posted June 27, 2022 The pitch is pretty shallow... can't remember exactly but quite a lot less than 45deg... I will ask Velux re springs... does anyone know if these are an expensive thing to replace? (or a pain in the bum to fit the replacements?)
JamesP Posted June 27, 2022 Posted June 27, 2022 Here is a video of spring replacement. Velux are usually very helpful.
Temp Posted June 27, 2022 Posted June 27, 2022 Is the friction adjustable? Ask Velux. Google found this but I've no idea ifbit fits your windows... https://www.loftsolutions.co.uk/shop/velux-spares/window-spares/velux-zoz114 Quote Velux Extra Strong Friction Hinge Clips ZOZ 114, for use with Velux ZZZ 125 Spring, for stiffening the opening of Centre pivot roof windows installed in a shallow pitch, comes with a 50ml tube of grease.
sneakyben Posted June 28, 2022 Author Posted June 28, 2022 interesting resolution: velux suppling stiffest springs they do FOC
Chablais Posted June 28, 2022 Posted June 28, 2022 you can adjust the springs, we have similar set up to you, and needed to adjust the pre load on the springs to enable the window to stay open at all. There are videos and pics online of how to do it. Best done at install time as some of the covers on the outside need to be off to access the springs and adjusters 1
