Anybody know current regs for boarding under stairs.
Im sort of thinking it needs doing to stop the stairs burning to give you chance to get down.
But what about open tread stairs, these wouldn’t have any form of boarding.
Thoughts before I phone building control.
Cheers.
Nod is right BUT.
I have had a very extensive argument with BCO on this. He was adamant that the regs said that the stairs must be non-combustible. The fact that we had completely boarded with 2 layers of plasterboard was of no interest to him. 'Wood is combustible.'
Eventually we prevailed.
I think you still have to board to protect the timber in a 'cupboard under the stairs'.  The risk being that a fire might start in a vacuum cleaner/plug etc, and go undetected until it burst through. Sounds sensible to me.
10 minutes ago, saveasteading said:
Nod is right BUT.
Normally the underside of stairs are boarded (30 minutes protection
But plenty are left open
I would ask BC what the point of having escape windows if the stairs are going to be fire rated
Cheers.
Fire resistance to the underside of a staircase in a standard  domestic dwelling is not required. Only where you have the underside of the stairs as part of the compartment between two dwellings does it need to be fire protected.
Limited combustibility/non-combustible staircases apply to commercial works - not domestic.
