Alwayslearning22 Posted May 4, 2022 Posted May 4, 2022 (edited) Hi does anyone have any idea why there’s a gap underneath my back door sill? There’s no mortar it’s just been left open, is it a movement gap or something? Could I fill this with expanding foam and silicone? thanks Edited May 4, 2022 by Alwayslearning22
joe90 Posted May 4, 2022 Posted May 4, 2022 8 minutes ago, tonyshouse said: Mortar for me +1 pushed well in to support the door sill. 2
Simplysimon Posted May 4, 2022 Posted May 4, 2022 would do both, low expansion foam to the back with mortar to the front. have you given the spiders notice to quit as they'll need time to find a new home? 1 1
Iceverge Posted May 4, 2022 Posted May 4, 2022 One side expansion foam and the other half mortar. Then report back to the forum after a thorough test! 1
Alwayslearning22 Posted May 5, 2022 Author Posted May 5, 2022 Thank you for the replies. I read somewhere that timber frames need Differential movement joints at door openings and window openings. ( i also have gaps underneath one of my window sills) Is this actually a done thing?
tonyshouse Posted May 5, 2022 Posted May 5, 2022 Yes but it shouldn’t be, windows often on packers should get sealant on the outside as a minimum door sills should not be unsupported 1
