IanMcP Posted March 22, 2022 Posted March 22, 2022 Hey so foundations soon going in. what have folks done with ducting for ASHP ? plant room isn’t on an external wall. Is it best to go down through the slab and come up 500mm externally with the feed / return / elec cable to the compressor. Or lay horizontal duct through ICF wall for simplicity. as ever , somebody has made these choices before please share 🙂
willbish Posted March 22, 2022 Posted March 22, 2022 I used a length of Uponor twin insulated pipe. Chuck in another duct or two for power and coms cables to the ASHP https://www.underfloorstore.co.uk/product/uponor-ecoflex-thermo-twin-pre-insulated-pipe
IanMcP Posted March 22, 2022 Author Posted March 22, 2022 Dam. Everything is so long to order ! through the slab I assume ?
Nickfromwales Posted March 23, 2022 Posted March 23, 2022 4 hours ago, IanMcP said: Dam. Everything is so long to order ! through the slab I assume ? Fast delivery from these guys normally... https://pipetek.co.uk/products/32mm-microflex-duo-heating-pipe-kit?variant=46263397322
Russell griffiths Posted March 23, 2022 Posted March 23, 2022 8 hours ago, IanMcP said: Dam. Everything is so long to order ! through the slab I assume ? Under the slab, not through it.
Happy Valley Posted March 23, 2022 Posted March 23, 2022 We put 3 pipes in the ICF prior to pouring the concrete having discussed the size of pipes required with the installer. The ASHP will be behind the garage.
makingprogress Posted January 22, 2024 Posted January 22, 2024 Hello - sorry to resurrect this thread - we are planning on putting our pre-insulated pipes from our utility room in the middle of the house, under the slab, and then in a trench to the rear of the garden. What happens if we ever needed to replace the pipes? Could we put them in some sort of ducting so we could remove / replace if needed? Cheers
