bobberjob Posted March 19, 2022 Posted March 19, 2022 Hi all just had a quote for a pv system with battery backup. 24 x 375 W panels and two batteries. All fitted and turnkey by Go-Energy £14750 + VAT with maybe some shaving to be done. £600 if I want to be part of selling any surplus back to the grid. i know it can be done cheaper DIY but it’s not for me. anyone had a quote from any contractors for anything similar?
CotswoldDoItUpper Posted March 19, 2022 Posted March 19, 2022 What size batteries? with the battery backup I doubt you’d be selling anything to the grid, certainly wouldn’t make back the £600 any time soon! I was quoted £4500inc vat for 4kW panels, no batteries flat roof mounted. £1250/kW yours is coming in at around £1600+vat/kW but includes the batteries. Guess that sounds about right or mb a bit expensive?
Thorfun Posted March 19, 2022 Posted March 19, 2022 it's hard to compare if you don't give us all the details. battery size/make, inverter, panel make/model, any optimisers/micro inverters, trays in-roof/on-roof etc.
bobberjob Posted March 19, 2022 Author Posted March 19, 2022 Batteries look to be Pylon Technolgies perlight duo mono black panels roof mounted on racks
Thorfun Posted March 19, 2022 Posted March 19, 2022 22 minutes ago, bobberjob said: Batteries look to be Pylon Technolgies perlight duo mono black panels roof mounted on racks Pylontech do 2.4 and 3.5kWh batteries. And you don’t say if it’s a hybrid inverter or an AC coupled system. Nor make/model of inverter. either way and making assumptions £14.5k seems a lot for the 10 panels, 2 x pylontech batteries and a hybrid inverter check online prices and compare with what’s on your quote.
nod Posted March 19, 2022 Posted March 19, 2022 We had PV in the planning for our first build Both my wife and myself hate the site of PV panels So decided to ignore and not install Projected cost 11k Annual saving £200-300 30 years payback Am I missing something We have omitted PV from our next two after speaking to our Sap guy and Architect Sap guy said PV will move you up 2 points Both said if you are looking at a financial return don’t bother
J1mbo Posted March 20, 2022 Posted March 20, 2022 Cost of PV seems to be 6-10p per kWh over its life. Cost from the grid is now 30p and will likely reach 40p by the autumn. Obviously paying up front for 20 years of electricity carries risk but it looks like annual returns in the 15pc range currently. All based on UK numbers.
JohnMo Posted March 20, 2022 Posted March 20, 2022 A quick look at current prices at ITS Technology (where I got my kit). A 12 panel kit (including everything for the kit to work incl mounts) is around £3500 (X2 for 24), 4.8kWh battery kit, £2400, so under £9500 incl vat. Plus install. (That includes 2x complete systems, some of which could be deleted) So they are charging you around £6-7k to install, which should be say 3 men for a day. £2k per man day, expensive. Unless there are some DNO charges for a big array, you have not shown.
J1mbo Posted March 20, 2022 Posted March 20, 2022 (edited) I don’t know that’s fair. Scaffold and access costs could easily be £1k. Running a company and providing a warranty costs money. For example the numerous regulatory schemes and bodies that will need paying, presales people, MCS administration, and of course all the usual overheads as well as those specific to solar contracts such as the 3rd party transaction insurance etc. Edited March 20, 2022 by J1mbo 1
bobberjob Posted March 20, 2022 Author Posted March 20, 2022 We are off mains gas so very high consumption of electricity 13000 kWh Even taking a loan payback would be less than five years and still be cheaper than our electric bill. Most of it for space heating and laundry in a small business in the summer excess units returned to grid at 5.5p could be worth about £3 per day why am I hesitating?? don’t know the contractor don't know the system don’t have £16000 quid lying idle in the bank etc etc i appreciate on costs for running a company so was just looking for some typical costs as a guide may look at a ground array and see if it would be cheaper? thanks for the replies very helpful
J1mbo Posted March 20, 2022 Posted March 20, 2022 (edited) All you can do really is get another quote and compare. A system using micro-inverters will be more expensive, for example, than one using a single hybrid inverter (a box that connects the solar panels and the batteries). It's better to use the power than export, since export at 5.5p is below your cost. A challenge with a 24-panel array could be using it all in the summer. If you have/are looking to an EV then that might not be so difficult. Otherwise we are stuck with batteries (as specified) and then heating stored hot water. What is your daily demand, May to August? Do you have an ASHP? If you're heating with electric that might be a better investment (would reduce heating costs by 2/3rds). Solar and ASHP are great together but obviously a lot of money to find. If you want to use the system to provide backup power, bear in mind that it won't be able to support everything. Usually a separate consumer unit is provided for 'emergency' maintained circuits (e.g. lights). There could be quite a bit of extra electrical work required too, for example a ground spike and various relays if the inverter doesn't deal with the latter. Edited March 20, 2022 by J1mbo
Thorfun Posted March 20, 2022 Posted March 20, 2022 +1 to getting more quotes! I always try and get 3 quotes minimum to get a good comparison. I do think your quote is a little on the high side but, as is mentioned, if you need to pay for scaffolding then that can add a substantial amount.
Dillsue Posted March 20, 2022 Posted March 20, 2022 At 9kw its quite a substantial system needing a G99 application. Our DNO charges £250+vat just to look at an application. Installers have got their admin and drawing to add to that. If 24 x panels are split over 2 pitches then scaffolding cost could be a fair bit. Assuming youve got a material schedule to go with the quote youll easily be able to work out material cost from online sellers. Our DNO told me a couple of weeks ago that they had received loads of G99 applications recently suggesting the trade is busy. If thats the case its likely a sellers market and you could be paying a premium just now. May be worth waiting til the autumn/winter when everyones forgotten about solar??
