11 minutes ago, Marvin said:
I don't know much about PV panels and the different costs or outputs of roof integrated ones, but I would use the ones that replace the tiles on a lovely new build.
Minimum of £11k for a 4kWp system........
6 minutes ago, SBMS said:
Indirectly?!
PV power to the batteries but no way for power from the batteries to go to the grid.
Got you. Whats your battery array capacity?
21 minutes ago, Nickfromwales said:
Not an MCS installation?
That's crammed in tighter than Brintey's postman!!
I needed a large delivery.
Self installed. DNO approved, (I have the bill) electrican finished.
MCS would have insisted on maintaining margins all around the perimeter, that's how I knew it wasn't an MCS install ;)
Yes the top and side are ok but the bottom a little different....
Have you considered using your concrete slab as a Battery?
If my calcs are correct, with no losses, an extra 1.5m3 of concrete holds 1kWh/degree.
Adding 75mm of concrete to your slab of say 100m3 will add 5kWh of energy storage per degree of temp you raise it. If you raise the temp of the slab by 3 deg overnight its a 15kWh battery for an extra ~£700 in cost.
Similarly an extra DHW tank at 300l can store 7kWh per 20 degrees.  We use an immersion to store 14kWh overnight, again at a cost of about £700.
The same ~ 30Kwh of Battery storage would cost over £10,000.
I was confused by this euphemism. Britney Spears postman ???
Just now, pocster said:
Must have missed that episode
I missed them all.
Did see some Simpsons when I was in Australia, was the only thing I could stand to watch.
