Airtightness & pendant lights upstairs
Cold roof, insulation in first floor ceiling/attic floor
For airtightness, want to minimise penetrating the ceiling
How to make pendant light fittings airtight,
or how to substitute pendants with something more airtight?
Drill the holes for the screws, pump in some silicon, screw fit as normal.
At the cable entry pump in silicon around the cable.
You could do ore from above if it is accessible.
Cold roof insulation vcl and 50mm service cavity is the way we went for air tightness. No need for anything to penetrate vcl.
Regards  James
Use offcuts of airtightness tape around the cables and behind the rose but the better option is just use service voids below the VCL/ACL where possible.
Regards  James
+1
