sorry, my fault, I didn't give any context for use, I'm temporarily removing the bracing on the roof trusses as the spacing on the bracing is too tight between the uprights and chords  So I can fit my inner layer of insulation.
Mulitool is very slow cutting through nails even with expensive blades. Knock or bar the timber back as far as you can then get a hacksaw in. Much quicker and easier
