saveasteading Posted April 16, 2023 Posted April 16, 2023 6 minutes ago, markharro said: pointless and just more money down the drain. If i am reading this correctly, you slats are entirely aesthetic, with gaps between. At some stage it becomes so open that insects are not interested.
AliG Posted April 17, 2023 Author Posted April 17, 2023 20 hours ago, markharro said: Hi @AliG I am just at the stage now of having to check this tedious fire barrier stuff - like you it seems we are having open timber cladding and it seems totally pointless. Our vertical battens are 45mm deep and horizontals 22mm giving 67mm in total. Is that similar to you? What product did you end up using - was it the Envirograf ? Also how did you deal with the Envirograf being blue I think and the Tenmat red when, you like, we are looking for something black to camouflage with our black membrane and battens etc? thanks. PS did you ask Building Control if you could just dispense with the stuff for the wall sections where you are using open cladding? Same with the insect mesh - both seem pointless and just more money down the drain. We used Tenmat I think as they are red. Eventually after a lot of arguing about it, the architects drew up every elevation of the house with exactly where mesh, Tenmat etc went. It was too difficult to tell just from a description. None of our cladding is full height, there is a band of render 500mm tall around the middle of the house, so the Tenmat was behind this. I don't think it would be noticeable behind the cladding however. Re your point though, I don't think the space behind open cladding is a "cavity" as it is not sealed and thus I don't think the regs apply here. Would probably need to check with BC. We used solid battens at the corners of the building as you don't need air to circulate around corners. The Tenmat is on areas where you need vertical air circulation. Originally the architect wanted it all around every window opening. MBC said that people normally battened around openings. The architects didn't like this as it would prevent air circulating behind the render board above the windows. Thus we agreed to solid battens at the sides of the windows and Tenmat above. There is no insect mesh at the bottom of the cladding as it is open. But if there is cladding next to renderboard, we treated the cladding area like a window and so had battens at the sides and mesh and Tenmat at the vertical junctions.
markharro Posted April 17, 2023 Posted April 17, 2023 Thanks @AliG thats a good point about the cavity - I think I will see if I can persuade BC on that. How many mm of gap between your cladding boards do you have out of interest?
saveasteading Posted April 17, 2023 Posted April 17, 2023 14 minutes ago, markharro said: thats a good point about the cavity I agree. I typed it up yesterday and forgot to send. Basically any insects want a secure a d sheltered cavity and yours doesn't sound like one. And fundamentally we are looking at the funneling of fire through a cavity, which you don't have. I don't think you necessarily need cavity barriers or insect mesh. Getting a bco to agree anything non standard re fire is tricky though.
AliG Posted April 17, 2023 Author Posted April 17, 2023 3 hours ago, markharro said: Thanks @AliG thats a good point about the cavity - I think I will see if I can persuade BC on that. How many mm of gap between your cladding boards do you have out of interest? 8mm
gavztheouch Posted August 22, 2025 Posted August 22, 2025 (edited) I have an open rainscreen. Bought the rainscreen from russwood after conversation with my BCO he confirmed the open rain screen is not a cavity and therefore we don’t need fire battens. However my architect thinks they are wrong and are arguing with the bco for me to put them in! I know they know how much it will cost but I hope they know how much work this will take if I have to remove all the battens to get access to the wood fibre to cut a channel round the house to receive a hard batten to take the expanding strip. This will comprise the membrane too. Nightmare. If I don’t do it properly then the whole exercise will have been a box ticking exercise. But then why challenge the original decision in the first place. Edited August 22, 2025 by gavztheouch
Kelvin Posted August 22, 2025 Posted August 22, 2025 Our architect put in metres of the stuff in the drawings. Thousands of pounds of it. I questioned it and then spoke with my BCO and we went through the regs and what he needed to see to comply. Saved us thousands of pounds. BCO was very pragmatic.
Nickfromwales Posted August 22, 2025 Posted August 22, 2025 3 hours ago, Kelvin said: I questioned it and then spoke with my BCO and we went through the regs and what he needed to see to comply. Saved us thousands of pounds. BCO was very pragmatic Its great to have a good BCO.
G and J Posted August 24, 2025 Posted August 24, 2025 On 22/08/2025 at 20:17, Kelvin said: Spoke with my BCO and we went through the regs and what he needed to see to comply. Saved us thousands of pounds. BCO was very pragmatic. Hi there @Kelvin, and others, can I ask what you used in the end behind your cladding. BCO's now are not "abke" to give advice, but will give approval to suggestions if appropriate. We are in Suffolk, timber framed, block on the ground floor, and t&g cladding above. The walls facing the neighbours have cement board sheathing and will have fire treated vertical t&g cladding. Neither of our gables face neighbours(both at 90 degrees), but we are considering putting intumescent strips in them behind the cladding. This has not been specified as necessary, but seems to the uninitiated, like a reasonable idea. (We will be using vertical timbers at the corner junctions) We are working with russwood and see their current recommendation is both pricey and out of stock, but notice they used to supply tenmat ff102/50.
Kelvin Posted August 24, 2025 Posted August 24, 2025 Envirograf CV30/8 from here: https://passivefireproducts.com/category/passive-fire-protection-products
