I got a lot of stud partition walls to make upstairs on our new build. After erecting the 4x2 frames I am thinking of boarding them with 11mm sob as I don’t like  placing plaster boards direct on the studs.
Would you say  that 11mm is a suitable thickness? I would like to go next thickness up but due to the amount I require and the current prices I feel 11mm is a suitable option.
Arnold9801
OSB?
What don't you like about plasterboard on studs? it is standard.
11mm OSB first then plasterboard will make the walls very strong indeed. I specified that once in a 'robust' school and it proved to be teenage boy proof.
Arnold9801
I used 11mm OSB behind my plasterboard in the kitchen and all units fixed fine.
Unless you have something very demanding if your using 11mm OSB should easily be OK.
Just curious
Why don’t you like placing plasterboards directly onto stud walls
OSB is not dimensionally stable, it can swell, expand and in extreme circumstances bow or”bubble”. If it gets wet it will be a problem, if the house gets damp or steamed up plasterboard is quite forgiving of one off water events, OSB not so forgiving, it is capable of moving studs, even pushing blockwork. I would leave expansion gaps, fit additional noggins.
9 hours ago, nod said:
Just curious
Why not just use Habito plasterboard
Better to fix to than OSB
Much stronger
man’s at about £20 per sheet
Much cheaper than using both
