Moggaman Posted December 5, 2021 Posted December 5, 2021 Hi. We are putting in a polished concrete floor in our new self build. My wife would like no skirting board at the wall floor junction. The walls will be plastered before the floor. there is a 25mm strip of insulation to go between the floor and the walls. Clearly If that is brought to the top , it will be seen. Slab is 75mm thick… can I stop the insulation at 50mm and run the slab over the top of the insulation?? I see no skirting on programmes a lot these days and wonder how they achieve it thanks
nod Posted December 5, 2021 Posted December 5, 2021 I’ve done this It’s normal to do the floor before the plaster As the expansion strip is vital to prevent the flood cracking
Moggaman Posted December 5, 2021 Author Posted December 5, 2021 (edited) 11 minutes ago, nod said: I’ve done this It’s normal to do the floor before the plaster As the expansion strip is vital to prevent the flood cracking Edited December 5, 2021 by Moggaman
Moggaman Posted December 5, 2021 Author Posted December 5, 2021 Because the walls are done after the floors in many cases , the plastering covers the expansion strip (insulation€ )… is that what you mean?
Moggaman Posted December 5, 2021 Author Posted December 5, 2021 So with my detail, I will have a 25mm insulation strip viable after the floor pour.. too wide to be covered by skirting……aaaaaahhhhh all these little details biting me in the ass ……
nod Posted December 5, 2021 Posted December 5, 2021 I’ve done these with both skirting and no skirting Either way the dot and dab plasterboard will cover the strip The ones I’ve done without skirting I’ve used a knock on stop bead on the bottom of the plasterboard Quite a nice look This will still allow movement
Moggaman Posted December 5, 2021 Author Posted December 5, 2021 17 minutes ago, nod said: I’ve done these with both skirting and no skirting Either way the dot and dab plasterboard will cover the strip The ones I’ve done without skirting I’ve used a knock on stop bead on the bottom of the plasterboard Quite a nice look This will still allow movement My finish is just wet plaster!
CalvinHobbes Posted December 5, 2021 Posted December 5, 2021 Is the function of a skirting board also to take the knocks? If you don't have one, after a year does it not look....scuffy?
nod Posted December 5, 2021 Posted December 5, 2021 You can’t plaster first Apart from the new plaster getting ruined while they are laying the concrete The plaster will suck all the moister out of the floor causing the skin to blow If you use a wet backing plaster (S&C) You will have to put a skirting on to cover the expansion gap 1
Moggaman Posted December 6, 2021 Author Posted December 6, 2021 How do people achieve that clean wall floor look then… ie no skirting.
Dave Jones Posted December 6, 2021 Posted December 6, 2021 shadowline looks good, you need a trim or stopbead for the plaster to finish on. https://www.barbourproductsearch.info/renderplas-makes-shadow-gaps-simpler-with-new-news016813.html
Moggaman Posted December 6, 2021 Author Posted December 6, 2021 2 minutes ago, Dave Jones said: shadowline looks good, you need a trim or stopbead for the plaster to finish on. https://www.barbourproductsearch.info/renderplas-makes-shadow-gaps-simpler-with-new-news016813.html Thanks Dave, they look good. Won’t about 5mm of the polyiso strip be visible tho!
Dave Jones Posted December 6, 2021 Posted December 6, 2021 shouldnt be the profile sits tight to the floor over the top of it. This is where you find out how good the screeder was.
Moggaman Posted December 6, 2021 Author Posted December 6, 2021 1 hour ago, Dave Jones said: shouldnt be the profile sits tight to the floor over the top of it. This is where you find out how good the screeder was. Sorry to labour the point but I’m not with you!. I will have sand cement render onto block as my internal finish. That’s probably 12mm to 15mm. The insulation is 25mm!.. won’t it be seen? my best option is a stop bead , maybe 10mm above ffl. Plaster down to this . Do floors with polyiso strip largely sitting under wall plaster and cover with skirting board… I can’t see another option.
Dave Jones Posted December 6, 2021 Posted December 6, 2021 you have two options. board the walls to bring it out far enough or cut back the insulation.
Moggaman Posted December 12, 2021 Author Posted December 12, 2021 Thanks for all the input here . I am going to plaster walls first from ceiling down to subfloor level .Quick question on expansion of the plaster?..I will have expansion insulation between floor and wall plaster. Will the wall plaster need room expand?.
saveasteading Posted December 12, 2021 Posted December 12, 2021 27 minutes ago, Moggaman said: Will the wall plaster need room expand? The plaster will shrink very slightly as it cures. if you are still doing skirting then the joint remains hidden, and no crack will be seen.
