Tooled up Posted November 30, 2021 Posted November 30, 2021 Hello guys, Building a SIP garden room from a kit. Having a slightly angled flat roof and we would like a sedum roof on the SIP panel roof. Thoughts? Weight? And can I use a typical EPDM for that? Be great to hear what you think? Cheers
tonyshouse Posted November 30, 2021 Posted November 30, 2021 Oversized joists at 300mm c/c 28mm wdp ply, fail safe low edge detail, drainage layer on top of torch on felt poor soil, sedum plugs water first year and if very dry second year my one still there on someone else’s house 30 years later , fall was 12 degrees though
saveasteading Posted December 1, 2021 Posted December 1, 2021 The calculation of carbon used as extra wood, as against any benefit from the sedum would be interesting. Also allow for plastic trays, if any, and special underlay. If you want the sedum for appearance then fair enough.
Tooled up Posted December 1, 2021 Author Posted December 1, 2021 thanks for the replies so far.... My roof panels are SIP so no joists (other than the timbers within/joining the SIP) So I guess I should speak to the supplier about load capability... .
saveasteading Posted December 1, 2021 Posted December 1, 2021 32 minutes ago, Tooled up said: load capability... When last I used it (reluctantly) it added 30kg/m2 to the roof, but that varies and can be up to 80kg which is a lot (allow for saturated earth). Please let us know how you get on.
Gordo Posted December 2, 2021 Posted December 2, 2021 (edited) I don’t see this as a wise change mid build. Flat roof is probably designed for a dead load of about 0.5 Kn/m2 dead load and you are thinking of adding an extra say 0.6 - 2 Kn /m2 ( probably closer to 1 Kn/m2 in my estimation for thin 75mm deep soil for sedums). Sorry but there is no way it was over engineered that much. You gonna have to do a lot of reinforcing works. Possible but costly so depends how big your pockets are for a whim here’s a guide on subject. I have a green roof on my log shed and I do love it but was done on cheap (because of what it is) but needs designed for at start. Edited December 2, 2021 by Gordo
