MAC address
I always thought these were unique.
But it would seem not. 2 raspberry pi's - same mac address. I've rebooted router/switch - still shows the same!!!. I want to give a unique fixed IP to each one ( based on the supposed unique IP address ) but it would seem I can't. Even unplugged one; reboot everything - still the same MAC address!. I thought the whole point of MAC was unique - what do I do!!!????
Edited by pocster
  • Replies 54
  • Views 7.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Looks like the Pi can load a MAC address override during kernel boot. https://raspberrypi.stackexchange.com/questions/68513/pi-using-a-random-mac-address-after-every-reboot-how-do-i-stop-this-beh
  • epsilonGreedy
    epsilonGreedy
    I thought the MAC address was fused into a network chip at fabrication time so could a procedural error in the fab plant cause this problem?
  • Same as mine ???? ( I am joking btw !!! )
Posted Images
I should point out when I 'swap' between these 2 it's the same physically connection on the switch. But that shouldn't matter should it?. Google isn't helping me
You can set the IP address up on each Pi in software, or use a hostname.
Edited by SteamyTea
I know that. But it's a bit tricky when multiple PI's have the same MAC address
How are you discovering the MAC addresses? On the Pi's themselves (running ifconfig or similar) or is it from the router's view of the world? If the latter then it is likely getting confused and/or showing misleading information. The MAC addresses *will* be unique so keep persisting...
what sort of Pi is it, then if I have one similar on my network, can see if it is the same as mine.
Yeah I detect router / switch are getting confused . But even powering off one pi . Reboot router / switch still shows same MAC address on different pi ! ?
Edited by pocster
It was a zero - though I have all variations ??
Does the router allow you to enter the MAC addresses manually? What router is it?
3 minutes ago, pocster said:
It was a zero
Here is my MAC
00:e0:2d:1a:23:0a
They're all going to be different, otherwise you wouldn't be able to use them on the same network.
Yeah I know - but something is confused
2 minutes ago, SteamyTea said:
Here is my MAC
00:e0:2d:1a:23:0a
Same as mine ??????
In theory, I suppose anything is possible. In practice it's not going to be the case. Occam's Razor suggests it is almost certainly a router issue, not least given the majority are built down to a price and are full of bugs.
Ok. I will stick to my specialist subjects namely software and climate change science.
6 minutes ago, pocster said:
Same as mine
Here is the address on another one, but an old one.
b8:27:eb:2c:9d:dd
7 minutes ago, pocster said:
Same as mine ??????
In case you were being serious there (hey, you never know! ;-)) are there any similarities between your setups e.g. same OSs, perhaps one built the Pis for the other etc? MAC addresses can be changed and it might well be the case that your OSs are changing them (to a fixed value, which is a bad idea).
b8:27:eb:2c:9d:dd
You can still use and abuse my MAC, just wipe it clean after.
This was driving me mad!
So I boot 1 raspberry pi at a time. It gets whatever IP address the DHCP server decides. SSH into it and edit dhcpd.conf (I think ). Few lines to get it a fixed IP address ( for everything else I set the fixed IP off the MAC in the router - as it's simpler ).
Have to do it this way - otherwise I can't tell what the hell's going on!. But as others have said all devices MUST have a unique Mac address when manufactured .....
Edited by pocster
Why not use a host name to SSH into.
You can, if you want, give it a number.
