Fraser Lamont Posted November 18, 2021 Share Posted November 18, 2021 Hi, anyone have any links to good u value calculators? Tried some from PIR manufacturers - unfortunately not all options are listed. I'm renovating a house and the spec seems stricter in Scotland than elsewhere regarding u-values for new builds, refurbishments, extensions etc. Building Control have specified my walls to be within this spec which is 0.22. The house is built with double block, outer leaf rendered 15>20mm, dense block. There is a 75mm cavity with inner leaf dense block. The entire structure will have a certain value before I add the insulation etc. I will be going down the route of installing PIR directly onto the inner face of inner leaf, taping then battening and dry lining the walls (warm batten). I'm looking for a calculator which will allow me to enter all these details if there is one out there. I have been looking at 100mm PIR but if I can reduce this even a wee bit, I'd be delighted. No biggie if I can't. Thanks Link to comment Share on other sites More sharing options...
Temp Posted November 18, 2021 Share Posted November 18, 2021 (edited) Is the cavity ventilated? If so the new wall is effectively going to be.. Plasterboard. Batten PIR Single Block Leaf Try that in the online calculators? Edited November 18, 2021 by Temp Link to comment Share on other sites More sharing options...
SteamyTea Posted November 18, 2021 Share Posted November 18, 2021 Only a few minutes to set up a spreadsheet and work it out yourself. Link to comment Share on other sites More sharing options...
Iceverge Posted November 18, 2021 Share Posted November 18, 2021 https://www.ubakus.com/en/r-value-calculator "HK33" will be EPS bonded bead in the material list. Link to comment Share on other sites More sharing options...
Fraser Lamont Posted November 18, 2021 Author Share Posted November 18, 2021 1 hour ago, Temp said: Is the cavity ventilated? If so the new wall is effectively going to be.. Plasterboard. Batten PIR Single Block Leaf Try that in the online calculators? yes, the cavity is ventilated. Link to comment Share on other sites More sharing options...
