Hi after some assistance, does know of a thermostat that can be installed in a bathroom.  The heating is wet UFH.  Ideally a wireless one, as would be easier to install.
The problem I have is, the thermostat is outside the room and I was going to have a probe through the wall.  But we moved the bathroom around and I now have a shower the other side of the wall.
The probe is usually a thermistor so there is no problem extending the cable, it does not need to be immediately the other side of the wall.
I left my Bathroom free run a bypass so to speak, with a reduced flow rate.Not sure if that helps or complicates the matter fro you.
That's what I did. Works fine. Mine is on about 8ft of wire.
Heatmiser Neo do a thermostat system where you can link a wireless battery powered probe.
https://heatmisershop.co.uk/heatmiser-wireless-air-sensor/
I beleive you will need a thermostat-
https://heatmisershop.co.uk/heatmiser-neostat-v2-programmable-thermostat/
and a neo hub
https://heatmisershop.co.uk/homekit-enabled-heatmiser-neohub-gen-2/
There will be cheaper options im sure on other websites and with that Hub you can add extra thermostats to make your whole heating system smart
Just a thought from what I have experiance in.
Just made a few changes to the way the UFH is working.
Did away with the bathroom thermostat all together, the manifold has self balancing actuators, so went for a simplified scheme altogether.
Timer to run pump with and without a call for heat, runs for about 14 hours a day.  Only have thermostats (simple dial type) in bedrooms now; to keep the bedrooms cooler than the rest of the house.  Only one other timer/thermostat to switch of the boiler on/off.
Thanks to the contribution on this and many other threads, I've read over the last few days.
