Vijay Posted October 27, 2021 Posted October 27, 2021 Need to buy one and a mate has suggested this one https://www.toolstation.com/qep-big-clinker-heavy-duty-tile-cutter/p15705 Just wondered if anyone has used that one or any other recommendations? Cheers
nod Posted October 27, 2021 Posted October 27, 2021 Sigma are the best and good value Also very easy to sell on 1
redtop Posted October 27, 2021 Posted October 27, 2021 (edited) Just tried to cut some 10mm floor tiles using a similar cutter and have now bought an electric wet cutter... It was impossible. Did wall tiles a breeze, I mean dead easy but no chance on Italian porcelain floor ones. Bought the cutter from screwfix, around 100quid new but got it 50 second hand Edited October 27, 2021 by redtop
Gone West Posted October 28, 2021 Posted October 28, 2021 I bought a Vitrex bridge saw and cut all the floor tiles, roof tiles and paving slabs with it. I was pleased with it and it worked well. https://www.vitrex.co.uk/products/versatile-power-pro-900-bridge-saw/
Vijay Posted October 28, 2021 Author Posted October 28, 2021 11 hours ago, Gone West said: I bought a Vitrex bridge saw and cut all the floor tiles, roof tiles and paving slabs with it. I was pleased with it and it worked well. https://www.vitrex.co.uk/products/versatile-power-pro-900-bridge-saw/ The problem with one of those is needing to cut outside I guess, that's a lot of up and down the stairs lol
Vijay Posted October 28, 2021 Author Posted October 28, 2021 On 27/10/2021 at 19:28, nod said: Sigma are the best and good value Also very easy to sell on Had a look at them and there seems to be different models, any suggestions on which model/series?
nod Posted October 28, 2021 Posted October 28, 2021 They at are all pretty good The 3B4 is light and cuts around 650 mil But will still make light work of up-to 20 mil thick tiles
Nickfromwales Posted October 28, 2021 Posted October 28, 2021 I’ve had Rubi cutters all the way from 400mm to 900mm and then a Sigma 900mm. Gave my Rubi one away to a mate starting out and I’ll be staying with Sigma. Outstanding bit of kit and far less effort to get a good cut. Literally couldn’t spot the difference between factory and cut edges.
Vijay Posted November 3, 2021 Author Posted November 3, 2021 Right, based on what you guys have said I'm looking at a Sigma. There is the 3B4 and 3B4M which I believe the 3B4 is a pull action and the M(max) is a push version (and slightly smaller cutting dimensions). From you experienced tilers, is a pull or push action better? The guy online said to go for a push action as it's what is used more and is more natural - but that could be cos he only had that one in stock lol
Vijay Posted November 3, 2021 Author Posted November 3, 2021 Ended up ordering the slightly larger Sigma 3C3M model
Vijay Posted November 10, 2021 Author Posted November 10, 2021 Starting using this cutter and having an issue. Scores fine but won't break evenly along the score line, the cut breaks off sideways. Spoke to the supplier which says it's down to the tiles, which are from Wickes https://www.wickes.co.uk/Wickes-Amaro-Linen-Porcelain-Wall+Floor-Tile---615-x-308mm/p/153690 they are slightly rippled which you can see in the pics. Anyone have any advice with this situation? I tried scoring a few times but still didn't break cleanly
Nickfromwales Posted November 10, 2021 Posted November 10, 2021 You're probably scoring too heavily. Try one clean pass, contact from start to end, and one sharp snap to complete. After that, you're on a wet bed cutter.
Vijay Posted November 17, 2021 Author Posted November 17, 2021 Guys, how clean of a cut should I be getting with this Sigma cutter? Cutting 8mm wall tiles, the tiles just aren't cutting cleanly, edges are raggedy and I'm ending up using a wetsaw to clean up the edges. Really not impressed with a £300 bit of kit
Vijay Posted November 18, 2021 Author Posted November 18, 2021 What are your thoughts on this cut with the Sigma? I can't use the cut tiles like this
Nickfromwales Posted November 18, 2021 Posted November 18, 2021 You're putting WAY too much pressure down on the cutting wheel. You should barely be scoring them. Go easy, tiger!!
Vijay Posted November 18, 2021 Author Posted November 18, 2021 17 minutes ago, Nickfromwales said: You're putting WAY too much pressure down on the cutting wheel. You should barely be scoring them. Go easy, tiger!! I tried really light pressure and it still did the same mate From what I can tell online, it's a 19mm wheel
Nickfromwales Posted November 18, 2021 Posted November 18, 2021 6 minutes ago, Vijay said: I tried really light pressure and it still did the same mate From what I can tell online, it's a 19mm wheel Wheel is too big. 10mm or 8mm is my preferred size, but there are many different grades of porcelain. I had some grade 5 on one job, and it was like breaking into the Hatten safe. 1
Vijay Posted November 18, 2021 Author Posted November 18, 2021 I'll measure it tomorrow to make sure 1
Vijay Posted November 19, 2021 Author Posted November 19, 2021 Deffo 19mm and I don't see how I can change it unless the whole handle is changed
