Window support, angle bracket.
& other details for builder
Ok? Not?
Inner block will have parge coat (ecoparge if available) + plasterboard on adhesive ribbon
Aircrete blocks are naff, move crack and have poor adhesion to mortar especially on perp joints
i used steel dowels to sit my bigger windows on built into the outside skin reveal
central angle bracket is useless if only fixed to the top brick, use 600mm heavy duty once bent strap fixed bottom middle and top to the masonry or a plate but plate would be a thermal bridge
As above
Solid concrete blocks are better Make sure the joints are well pointed I use tons of parge coat per year
Complete waste of money and will encourage dabbers not to run continuously dabbs
Why is parge coat a waste? (apart from encouraging poor workmanship from dabbers)
Cracking?
Porotherm standard practice is ecoparge (not using Porotherm here, but we assumed same principle applies)
Edited by WWilts
I did similar, my cills are angled bricks which overshoot the cavity a little, rested the windows on the cills and used the same brackets as you up both sides. I used expanding foam tape between window and surrounding brick (my windows fitted check reveals, I.e. windows fitted to inside skin of outside brickwork). As we had solid render and plaster coating inside I only parged between floors where plaster etc did not extend.
Cracking?
As a business We use it for sound coating
The air should be getting to the block work
The boards and ceiling should be sealed
and around all the sockets
I’ve been using Parge for over 30 years Sand and cement before that While it’s effective for sound deadening It’s a waste of money for airtightness
When it is specked in a contract I always refer to it as sound block As I’ve already said it encourages the plasterers that work for me not to seal everything off probably
If warm air is getting through to the block work You’ve got problems
One large company that we do around 40 houses per year for used Parge on every house and every wall That stoped about 5 years ago when they agreed to pay there brickies an extra £1 m2 to point and bar rub every joint
No more gaps and snots Parge on party walls only
Edited by nod
Even with a parge coat you'll likely get cracking on aircrete blocks. I'd go even further than this, and use a parge coat with embedded mesh, this may give a little more resilience.
Will tooled concave joints do the trick re air tightness?
That's what the builders are doing
Edited by WWilts
