GrantMcscott Posted October 13, 2021 Posted October 13, 2021 Hi Looking for low profile IP65 fire rated downlights. Service cavity is 45mm and plasterboard is 15mm above service cavity there is VCL and 150mm of PIR insulation. I was going to go with the JCC V50 and contacted their support about the insulation. The response back was that they said there would be no problem with heat but their documentation states it needs 75mm of space all around it. Do not want to install them and they start failing. Can anyone recommend a low profile downlighter had a look at the Nitro pro as well
vala Posted October 13, 2021 Posted October 13, 2021 Would these work https://www.cef.co.uk/catalogue/products/4864836-mpro-6w-led-fire-rated-dimmable-downlight-without-bezel-3000k?gclid=EAIaIQobChMIjNOzrKfI8wIVZWHmCh2TbAXvEAQYCiABEgJ3uPD_BwE&gclsrc=aw.ds 1
Temp Posted October 13, 2021 Posted October 13, 2021 Nice flat panel LEDs are the thing now.. https://www.google.com/search?q=flat+led+downlight&sxsrf=AOaemvIrKvuNN43dOQbWNLnaBlzEeD1KtQ:1634162334405&source=lnms&tbm=isch&sa=X&sqi=2&ved=2ahUKEwjh1MmLscjzAhV6g_0HHQYgCLsQ_AUoAnoECAEQBA&biw=1575&bih=856&dpr=1 1
Arnewhouse Posted October 13, 2021 Posted October 13, 2021 Have ordered these for our new build. Will fit with 45mm batten. Not fitted yet but look and feel nice. https://www.electricalcounter.co.uk/products/Lighting/Indoor+Lighting/BG+Indoor+Lighting/Luceco+Domestic+Lighting/FType+Compact+Fire+Rated+Downlights/FType+Compact+Regressed+Dim+Fire+Rated+LED+Downlight+6W+3000K+IP65/564191902 1
TonyT Posted October 13, 2021 Posted October 13, 2021 I prefer a fitting with a lamp that you can replace instead of having to change a fitting 1
