Celotex insulation boards
Has anybody bought any of this recently or know if you can buy direct? I need to cover about 400 square meters? Any help appreciated!
I bought 100mm, 50mm and 25mm end of last week and had them delivered Tuesday just gone. Much lower quantity then you're after though.
Ordered from insulationshop.co
All were received in excellent condition.
I am generally a fan of buying direct from manufacturers where I can. I tried with Celotex and got nowhere. In the end I used a local insulation firm after comparing prices. I bought a flat-bed lorry full at Christmas for my foundations. I was pleased with the price.
  • 4 weeks later...
I bought from insulation hub, came direct from factory delivered to my door, delivery at no cost (NE Scotland) 400m2 of 100mm thick.
have you tried local builders merchants? I have 2 local builders merchants and both came back with cheaper prices for Recticel and EcoTherm PIR than I could find online. plus I have an account with them so don't have to pay upfront and I'm supporting local business. ?
Of what thickness..? Floor..? Wall..? Roof..? Lots of variables which will impact this.
Seconds&Co can be good sometimes but tbh if there is a big (ie £10k order) then your local merchant can usual be good. And go with their brand - Recticel, Kingspan, Celotex,Ecotherm are all just brands of PIR.
Had a delivery of 30 sheets of 120mm this week from sec&co, to cut and fit between rafters, was concerned about their delivery as they make a big thing of double decker sized wagons...  Anyway all went well, we handballed the insulation off the lorry, the stuff for the most part is good, 5 or 6 sheets are slightly concave on the edges, but my festool will sort that out.
As a test run, all positive, so will be ordering more soon, and they seem to be back to adding stuff to their inventory again.
I also bought about 100 sheets from Insulation Hub,  Came direct from manufacturer on the day I requested they used a tag on forklift to unload themselves.
