Probably yet another stupid question but is it OK to fit the windows and french doors before the roof is slated? Will the timber frame settle a bit and then things wont open after the weight of the slate is added?
Absolutely fine
Your scaffolding should be right under the soffit So no chance of anything falling through
You could stand some ply in front of f doors bifold etc
As above and yes the timber frame will settle a bit but it is going to do that over the next few years anyway hence the compressible strip around windows etc.
That's what we did just under 5 years ago. Our TF included a warm roof 3rd floor which was sarked. The frame and windows were erected in Nov. The slates went on in Feb. No probs at all.
Edited by TerryE
Meant sarked rather than racked.
No problem. We had some scratches on one frame from falling slates.. happened when scaffolders were moving boards and I didn't clean up before hand and debris dropped down. Keep your scaffolding clean and don't throw slates...
We had an external stone skin added to our TF the following summer. Our windows were triple glazed Internorm Aluclad.  One thing that we did do was to cover them all with a building grade polythene protection pretty much soon after they went in.  The last stage of the stone work was to careful cut around the widow frame / stonework junction, remove the polythene sheets then do the final pointing fillet.
Edited by TerryE
