Moggaman Posted September 8, 2021 Posted September 8, 2021 Hi all see photo of roof going on in my house. U will see I have an overhang on my roof. On my drawings it shows a column at the outside to support the rafters and roof. It’s not structural , just there to prevent sag on the rafters. Column would need to be about 3.7m long. Have you any suggestions on what I would do?.. A galvanised steel Column classed or perhaps a steel circular column? thanks
nod Posted September 9, 2021 Posted September 9, 2021 U could use MF I stud Or Met-set (Structual) and clad with the material of your choice
Moggaman Posted September 9, 2021 Author Posted September 9, 2021 14 hours ago, Ferdinand said: No photo ? Sorry! One up now
Mr Punter Posted September 9, 2021 Posted September 9, 2021 You could have galv steel but it needs to be connected at the base and at the top it will need to pick up all the rafter feet that need support, so you will need something fabricated. Tube section / CHS looks good. Is it going where it won't be accidentally walked into?
PeterW Posted September 9, 2021 Posted September 9, 2021 Why not just add in a 4x2 glued and screwed to the rafter tails and 600mm up from the wall plate ..? Would stiffen the rafter ends, then glue and screw a ply/OSB sheet under the tails which would essentially make it a single cassette that doesn’t need any post. Only other thought is use it for the downpipe ..?
joe90 Posted September 9, 2021 Posted September 9, 2021 As per @PeterW says, just stiffen it, sister it with 2” timber by same depth with glue and screws. forget the post (you will only walk into it)
Ferdinand Posted September 9, 2021 Posted September 9, 2021 2 hours ago, Moggaman said: Was thinking it was another of those stealth house things.
