August 19, 20215 yr 1 minute ago, epsilonGreedy said: @joe90 Not that photo again! I have only just recovered from post traumatic viewing syndrome since the previous posting. Ha, I have another one before they sewed it back together with tendons hanging out, I decided against that one ?
August 19, 20215 yr Good for sanding metal railings, never seen a first fix joiner use anything like it…
August 19, 20215 yr Our framers seemed to use nothing other than a chainsaw for the whole cut roof...
August 19, 20215 yr 2 hours ago, SteamyTea said: New blades don't much, blunt ones do. Or the jiggler/shaft on the saw is worn. I use an angle grinder for just about everything I can. and starting ?s LOL.
August 19, 20215 yr 4 hours ago, Marvin said: and starting ?s LOL. I do that with the arc wielder, touched a can of WD40 that a dickhead workmate put on the wielding bench when I had the mask down.
