Condensate on vertical flue?
Do we need to worry about condensate?
SWMBO would like a wood burning stove with a completely vertical flue that exits out the top of the appliance and runs straight up through the roof.
This is instead of exiting the back of the appliance and running through an outside wall into a "T" with the flue on top and a drain on the bottom.
Will we need to do anything special for condensate or can plain flue (we propose black painted double wall all the way from the appliance up) sit directly on top of the appliance?
The house is a timber frame. It is a warm pitched roof with no attic/sloping ceiling. The flue would run for ~2.5 metres internally, ~0.5 metres through roof structure, then ~2 metres externally.
This is the stove we're considering: (2.5-7 kW, 130 mm flue, external air feed, a semblance of convection hating / shielding to avoid surfaces being too hot)
https://www.senukai.lt/p/kietojo-kuro-krosnele-abx-viking-i-black-7-kw/ejvd?cat=b88&index=16
http://www.abx.cz/cs/viking-i--cerny-korpus-oplasteni-cerny-plech-p805v17
Yes, and no.
No, because - at the ideal burning temperature - you have put dry  (<15%) wood on the fire , and yes if the wood is .....
How you deal with the condensate is another matter.
A standard twin wall insulated flue, has the inner joint overlapped such that if there is any condensate, it will run down into the stove (and evaporate again) rather than run out at the joints and down the outside of the flue.
