Ultima357 Posted July 27, 2021 Posted July 27, 2021 Having lived with MVHR for 9 months I have just completed a DIY active carbon filter as my neighbours just like stinky bonfires too much. Whilst you can easily shut it off when you're at home, it is a horrible surprise to come home to find your home smelling like a bonfire. So I began to research active carbon filters and found those commercially available ones were stupidly expensive and the cost of replacing the filters was also the best part of an arm too. I began therefore at the actual active carbon filter and found that these are many and varied and a huge range of costs. Looking at what I had room to install I decided to get as large a filter as possible and at reasonable cost. I chose one designed for plant nurseries as they are both compact and low cost and got one rated at 600m3/hr with an estimated 3 year life. Again I found a variety of prices but being an experiment, I decided on one costing just over £40 delivered. You can find similar for up to 3 times this. Pictures show the construction of a 450 x 400 x 400mm box in 12mm mdf mainly, just the end out with 18mm to give a greater rigidity for the filter mount/seal. Installed it today and already tested tonight as just had to shut windows due to stinking bonfire again! Running at 220m3/hr currently with no smell whatsoever. Well pleased. Total cost less than £70 for materials. Being retired I don't count my labour. Monitoring the MVHR it has given some additional load/back pressure as expected, increasing the input fan speed by between 50rpm and 500rpm depending on m3/hr selected. The higher rate when running at 330m3/hr. At 100m3/hr its around 150rpm up. MVHR is Brink Flair 400. If this continues to perform, I might go for a higher cost filter with less back pressure when I replace it or see if I could squeeze two of these in parallel into the space I have. Should be possible. Just another 30 quid for more mdf and a few more hours making it. I rebated and glued joints to keep it airtight apart from the lid which is rebated and just screwed down. Hope this might inspire others to give it a go. Filter from Future Gardens, Assasin 600m3/hr. MDF from wherever you can get it. Just two quarter sheets. Plus a few hours design and sawdust making on my cnc router table but could be done using a hand router and table saw if you have a good eye for square and straight edges... ? 3 2
PeterW Posted July 27, 2021 Posted July 27, 2021 Nice idea - that MDF needs a couple of good coats of decent eggshell or gloss to stop it absorbing moisture though.
dpmiller Posted July 28, 2021 Posted July 28, 2021 what weight is the filter, and what size of granule? First one gives a clue about how much you can adsorb, second is related to flow restriction and rate of adsorption. / used to spend a lot of time working on duct-free fume cupboards...
Nick Laslett Posted July 28, 2021 Posted July 28, 2021 On 27/07/2021 at 20:30, Ultima357 said: Having lived with MVHR for 9 months I have just completed a DIY active carbon filter as my neighbours just like stinky bonfires too much. Whilst you can easily shut it off when you're at home, it is a horrible surprise to come home to find your home smelling like a bonfire. …*snip Expand Thank you for highlighting this. I’m still a long way from finishing my build, but this issue with MVHR sucking in bonfire smoke seems like a potential problem for some sites. This is a potential downside to MVHR that needs to be flagged up during the design stage, so that it can be planned around.
Ultima357 Posted August 8, 2021 Author Posted August 8, 2021 Sorry for late reply everyone. I set it to flag me on responses but it didn't! Anyway, as for data on how much carbon granules are in it, there is no data on it, but it weighs circa 3 to 4kg and I'd guess the housing being aluminium will be only 500gm of this. There are similar carbon filters such as Carboair which have more data and are probably better. Of course more expensive too and as I am experimenting I choose a low cost item to start with. Typically they filter :- Pesticides/herbicides 0.001nm Paint pigment 1-5nm Odours/Diterpenes 1-10nm Mould spores 10-30nm Plant spores 3-40nm Common dusts 30-600nm Plant pollens 10-1000nm The active carbon bed is 50mm thick. I coated the mdf with two coats of external grade water based clear lacquer to seal it. It's situated on the house supply side so shouldn't get overly moist. As for planning one in at the start, I'd say just give yourself enough room and go my route. The branded mvhr filters are very expensive and I would expect they sting you for replacement filters. As mine is rated for 600m3/h with a life of 12 to 18 months, and I generally run at just 100m3/h, I'm expecting a life of at least 2 years. Time will tell but it's on the prefiltered side so only dealing with the smells, not too much dust, so should be OK. Maybe when it's time to replace I'll use a more expensive version with less back pressure or put a couple of these in parallel in a larger box. I need to make fitting a replacement easier for sure but it's in and working well.
dpmiller Posted August 8, 2021 Posted August 8, 2021 you can always stick it in the oven and bake the odours back out again...
SteamyTea Posted August 9, 2021 Posted August 9, 2021 On 08/08/2021 at 17:35, dpmiller said: you can always stick it in the oven and bake the odours back out again... Expand Or report neighbours to the council.
Ultima357 Posted August 10, 2021 Author Posted August 10, 2021 On 09/08/2021 at 10:14, SteamyTea said: Or report neighbours to the council. Expand Smoke is a very difficult thing to track down sometimes. Tonight we have a countryside scent outside, local pig farm by the smell, thankfully the filter is doing the job!
Ultima357 Posted September 23, 2021 Author Posted September 23, 2021 Final comment. Having lived with it for several weeks I can now say it works fantastically well. Yesterday, someone close by was burning rubbish including rubber by the smell of it. Quickly closed doors and windows (it was a nice warm sunny day) and result, absolutely no smell inside. Outside was purgatory! So if you're considering this, based on my experience I'd unreservedly recommend doing it. 1
CalvinHobbes Posted September 23, 2021 Posted September 23, 2021 Very impressed! Have made a note of this for our build. Thank you.
Ultima357 Posted July 17, 2022 Author Posted July 17, 2022 Update to this filter. After proof of concept with the low cost and relatively low volume flow filter, I have now rebuilt the whole unit using a much larger filter rated at 2400cu m/hr. The reduced back pressure means the fan works at lower rpm whilst maintaining the throughput and at maximum 330cu m/hr of the MVHR there is very little difference between the in and out fans rpm wise. Given the flow rating of the filter (Phresh 600 x 300), I'm expecting a lot of years service before any need to replace it.
SteamyTea Posted July 18, 2022 Posted July 18, 2022 On 17/07/2022 at 20:46, Ultima357 said: I have now rebuilt the whole unit using a much larger filter rated at 2400cu m/hr. Expand Good stuff. Do you have pictures and prices?
Ultima357 Posted July 18, 2022 Author Posted July 18, 2022 No unfortunately I built it in a hurry and didn't take photos and it's a bit too warm to go up the attic at the moment. The filter I bought from Future Gardens https://www.futuregarden.co.uk/phresh-premium-filters. It's the 600 x 315 @£188. The cabinet housing I used 15mm mdf and used one and a half sheets. The two sheets cost just under £80 these days with cuts as required so I could get it all in my car. Fortunately I have a CNC router table so able to accurately cut out the required holes and rebates for jointing, so all in around £250. The filter is quite a beast as the 315 refers to the inlet diameter and its around 440mm diameter overall and weighs in at around 18kg if I remember correctly. Basically it's a big box with raised plinth inside across 2/3rds of the depth to hold the filter and provide the appropriate airway flow. Mounted it vertically as that was all I had space for.
skhell Posted December 14, 2024 Posted December 14, 2024 Bumping up this thread 🙂 Great build you have there @Ultima357! I am having issues with fireplace smoke from the neighbours getting in the house through the MVHR system. I tried some activated carbon filters with some success, but in some occasions, they are not enough. I think that the reason this panel filters don't work in some occasions is they have small ammounts of filters I think that I need a more substantial filter the one this build. @Ultima357 I have a couple of questions: If I understood correctly, you have the filter after the MVHR unit, and before the manifold where you connect all pipes that goes to the individual rooms, right? The filter inside the box is connected to pipe that goes manifold, or connected to the pipe that comes from the MVHR unit? I can make the question in other way, the MVHR unit is blowing air into the box, or into the inside or the filter?
Ultima357 Posted December 14, 2024 Author Posted December 14, 2024 On 14/12/2024 at 09:42, skhell said: Bumping up this thread 🙂 Great build you have there @Ultima357 @Ultima357 I have a couple of questions: If I understood correctly, you have the filter after the MVHR unit, and before the manifold where you connect all pipes that goes to the individual rooms, right? The filter inside the box is connected to pipe that goes manifold, or connected to the pipe that comes from the MVHR unit? I can make the question in other way, the MVHR unit is blowing air into the box, or into the inside or the filter? Expand Hi. My system pumps from the unit into the bottom of the box containing the filter. The filter sits above this on a baffle board, so the air pumps into the centre inlet of the filter and out the exterior of it. Then flows around the box back out to the manifold of the mvhr for house distribution. My neighbours love bonfires and this copes fine with them. Ditto the occasional smell of the countryside from muck spreading etc. So effectively I have a large box with a smaller box/baffle inside at the bottom which acts as a duct for the incoming air into the filter. If it doesn't make sense, let me know and I'll try and draw it up and post it on here.
skhell Posted December 14, 2024 Posted December 14, 2024 On 14/12/2024 at 12:04, Ultima357 said: Hi. My system pumps from the unit into the bottom of the box containing the filter. The filter sits above this on a baffle board, so the air pumps into the centre inlet of the filter and out the exterior of it. Then flows around the box back out to the manifold of the mvhr for house distribution. My neighbours love bonfires and this copes fine with them. Ditto the occasional smell of the countryside from muck spreading etc. So effectively I have a large box with a smaller box/baffle inside at the bottom which acts as a duct for the incoming air into the filter. If it doesn't make sense, let me know and I'll try and draw it up and post it on here. Expand HI! Thank you for the clarification. I think I understood, but if you can make a sketch, it would be great! Is there any reason for that baffle? Why didn't you connected the hose coming for the MVHR unit to the center of the filter? Without the baffle?
Ultima357 Posted December 14, 2024 Author Posted December 14, 2024 On 14/12/2024 at 12:35, skhell said: HI! Thank you for the clarification. I think I understood, but if you can make a sketch, it would be great! Is there any reason for that baffle? Why didn't you connected the hose coming for the MVHR unit to the center of the filter? Without the baffle? Expand The baffle supports the filter which is mounted vertically, inlet at bottom and gives the airflow route. See picture. The red line is the baffle inside the box, the blue/red the filter and green represents the airflow. Basically the baffle divides the box internally to give separation of air so it has to flow through the filter. It's an L shape. The box is 600mm sq by 1000mm high. Second one shows the baffle inside in red, the dirty incoming in purple and green filtered air. Blue dashes the filter. The white dots the inside edges of the box. 1
Ultima357 Posted December 14, 2024 Author Posted December 14, 2024 Sketch re above looking inside box. 1
skhell Posted December 14, 2024 Posted December 14, 2024 Excellent! Now I fully understand your build. Awesome work! Do you notice any carbon residues leaving the filter? Do you see the need for a fine particle filter after the carbon filter?
Ultima357 Posted December 14, 2024 Author Posted December 14, 2024 On 14/12/2024 at 15:49, skhell said: Excellent! Now I fully understand your build. Awesome work! Do you notice any carbon residues leaving the filter? Do you see the need for a fine particle filter after the carbon filter? Expand To be honest, I've never looked inside the box since I screwed the lid down. I wouldn't think it would be a problem as the filter is very large, designed for 600m3 flow rate, so pulling a steady 100m3 or even flat out 330m3 in my case, I don't think that carbon dust will be an issue. Everything is static, no vibration, etc. I'm thinking that another fine enough filter to catch those very fine particles would put too much back pressure on it.
skhell Posted December 14, 2024 Posted December 14, 2024 Have you considered using a inline filter, such as of these: https://www.led-grower.eu/uhlikovy-filtr-inline-phresh-filter-pro-1275m3-h-o200mm/ https://www.led-grower.eu/carboair-inline-1200m3-hod-o200mm/ Although more expensive, there is no need spend extra money in the materials to build the box. I am seriously considering one of those.
Ultima357 Posted December 15, 2024 Author Posted December 15, 2024 They look pretty good though you'd need some adaption to match the diameter of the inlet and outlet. And of course the space needed for the length of the inline configuration. You'd possibly also need to insulate the outside depending on the location of it. Can't see any reference to backpressure, but being made by Phresh and having such a large flow rate that shouldn't be an issue. Price wise probably cheaper than mine plus box materials.
SteamyTea Posted December 15, 2024 Posted December 15, 2024 On 14/12/2024 at 17:48, Ultima357 said: I'm thinking that another fine enough filter to catch those very fine particles would put too much back pressure on it. Expand Generally you don't need fine filter material to get most suspended solids out if the air. The filters we used to make worked by slowing the airspeed until the particles literally dropped out due to gravity. There is a method that works the opposite way, speeding up the airflow and allowing 'lighter' air to be diverted, with the particles carrying on in a straight line into a catchment container. How some vacuum cleaners work and how military aviation air filters keep the sand and salt out of the reciprocating engines.
Ultima357 Posted December 15, 2024 Author Posted December 15, 2024 On 15/12/2024 at 16:32, SteamyTea said: Generally you don't need fine filter material to get most suspended solids out if the air. The filters we used to make worked by slowing the airspeed until the particles literally dropped out due to gravity. There is a method that works the opposite way, speeding up the airflow and allowing 'lighter' air to be diverted, with the particles carrying on in a straight line into a catchment container. How some vacuum cleaners work and how military aviation air filters keep the sand and salt out of the reciprocating engines. Expand Yes there are ways to do it with varying airflow but with MVHR you don't have that control. The air filtration on agricultural machinery are also equipped with vortex filters.
SteamyTea Posted December 15, 2024 Posted December 15, 2024 On 15/12/2024 at 17:13, Ultima357 said: The air filtration on agricultural machinery are also equipped with vortex filters Expand Don't matter on them, they all have flat batteries, so never start.
