Hi all,
New member here, and keen DIYer.
I’m looking for help with my current project. I’m installing a shotgun safe - it will be bolted into solid wood floors, which has worked fine,  but then I’m bolting the back of it to my wall.
I assumed the wall was plasterboard, and bought GRIP-IT plasterboard fixings, which I’m very familiar with having used them on other walls.
I drilled the 25mm hole, however, found the wall was 3cm thick, followed by a cavity (1 inch), followed by some insulation.
I have never seen plasterboard this thick, and can’t find anything online about such thickness plasterboard. The material is chalky like plasterboard.
As I thought it was plasterboard, I then bought the GRIP-IT undercutting tool to try and carve out a channel for the product’s “wings” as the wall was too deep for standard fixings, however, this hasn’t worked - the wings don’t have space to open! That’s the reason why in the photo attached appears to have a channel/void.
Could anyone please advise:
1) what building material this is?
2) the strongest way I can bolt into it?
Thank you in advance!
William
It’s an internal wall between my apartment and the communal hallway, in a modern build. It seems to be the wall in the photo attached, cavity, insulation then another wall which goes onto the hallway.
Looks like a hollow block - use a toggle bolt to get behind it into the cavity.
Has you licencing officer told you that is ok as a location ..? Local one here wouldn’t pass that.
Gun safe should be on an internal wall, if this backs onto a hallway or other communal area then it shouldn’t pass inspection
7 hours ago, PeterW said:
Has you licencing officer told you that is ok as a location ..? Local one here wouldn’t b
pass that.
No way that would pass by my local firearms officer, I thought it had to be bolted to a solid external wall.
Double boarded plasterboard for sound insulation?  As above, you really need something solid to fix to.  Can you find a stud?
I built-in some 6×2 noggins in a stud wall to coach-bolt to.  I reckon it's as good as fixing to blockwork.
