James Duke Posted July 13, 2021 Posted July 13, 2021 Hi, does anyone have any experience of constructing a stud wall on top of a floating floor? Thanks James
Russell griffiths Posted July 13, 2021 Posted July 13, 2021 Loadbearing?? non loadbearing ?? what do you want to know, build wall screw it down to floor sheets, that’s about it isn’t it. Ps. don’t screw through any pipes. Job done.
markc Posted July 13, 2021 Posted July 13, 2021 Screw through the floor into whatever is underneath. once saw a flooting floor with stud wall fixed just to the upper floating part ... heavy doors played havoc with plumb and the floor
nod Posted July 13, 2021 Posted July 13, 2021 You would normally fix a sole plate to the floor for your studs layout Then install your floor in each room With a 20 mil expansion gap around each sole plate and the perimeter You shouldn’t fix anything through the FF 1
James Duke Posted July 13, 2021 Author Posted July 13, 2021 2 hours ago, nod said: You would normally fix a sole plate to the floor for your studs layout Then install your floor in each room With a 20 mil expansion gap around each sole plate and the perimeter You shouldn’t fix anything through the FF Thanks nod. I was thinking of taking the FF up as the insulation and chipboard is damp due to a leak. Fixing a soleplate to the concrete and building the stud wall up from there, then re-laying the floor on either side of the new wall. I understand the concrete has a DPM on top so can I screw into this or is there another way of fixing the sole plate?
James Duke Posted July 13, 2021 Author Posted July 13, 2021 Also, with a 20mm expansion gap, how do I go about filling the gap on the finished floor? I'll be using a flexible flooring of some description but 20mm is too wide to be covered by normal skirting. Thanks.
nod Posted July 13, 2021 Posted July 13, 2021 If you roll a length of dpc un the sole plate Then fix through it Im guessing you already have plaster on the wall If so reduce the gap to 10 mil and cover the gap with the skirting board But you need to leave the gap clear
Russell griffiths Posted July 13, 2021 Posted July 13, 2021 3 hours ago, nod said: You would normally fix a sole plate to the floor for your studs layout Then install your floor in each room With a 20 mil expansion gap around each sole plate and the perimeter You shouldn’t fix anything through the FF Shows I know nothing ??♂️ 1
James Duke Posted July 14, 2021 Author Posted July 14, 2021 16 hours ago, nod said: If you roll a length of dpc un the sole plate Then fix through it Im guessing you already have plaster on the wall If so reduce the gap to 10 mil and cover the gap with the skirting board But you need to leave the gap clear Thanks Nod, this has been really helpful.
nod Posted July 14, 2021 Posted July 14, 2021 1 hour ago, James Duke said: Thanks Nod, this has been really helpful. ?
