Robert Clark Posted June 27, 2021 Posted June 27, 2021 Hi Guys We’re having a screed laid soon and plan to have Antico flooring laid on top. Our builder is suggesting using a fast drying liquid screed, but our flooring supplier suggests a traditional screed as it can have a damp proofing sealer applied on top if needed before laying the Antico, whereas he claims that fast drying screeds cannot, Which option would you choose ? Thanks
nod Posted June 27, 2021 Posted June 27, 2021 I tile on lots of both Liquid is more expensive But flatter Traditional needs a day per mil to dry out 75 days typical Liquid is good to go after a week You will needs membrane under both So damp won’t be an issue with either 1
Robert Clark Posted June 27, 2021 Author Posted June 27, 2021 37 minutes ago, nod said: I tile on lots of both Liquid is more expensive But flatter Traditional needs a day per mil to dry out 75 days typical Liquid is good to go after a week You will needs membrane under both So damp won’t be an issue with either Do you apply Antico on liquid screed after a week ?
nod Posted June 27, 2021 Posted June 27, 2021 17 minutes ago, Robert Clark said: Do you apply Antico on liquid screed after a week ? No experience of Antico But the screed needs to be fully dry before ceramic tiling or they will blow I would think Vinyl would be the same
Nickfromwales Posted June 27, 2021 Posted June 27, 2021 @Robert Clark I assume you’re referring to Amtico aka LVT? ( Luxury Vinyl Floor ).
Robert Clark Posted June 27, 2021 Author Posted June 27, 2021 3 minutes ago, Nickfromwales said: @Robert Clark I assume you’re referring to Amtico aka LVT? ( Luxury Vinyl Floor ). Yes
Nickfromwales Posted June 27, 2021 Posted June 27, 2021 Ardex A38 dry screed can be ceramic tiled in 4 hours. Cementitious tile adhesive is completely different to the type of adhesive that the Amtico layers will use. There is an even quicker drying dry screws available, but I can’t remember the bloody name of it. I’ll ask my mate, he’s my got to screeder ( who will travel btw ). He laid @Russell griffiths screed. PM him if you want a reference. Top guys. You need to petition the fitters to find out what they’ll use before getting any more advice based on unknowns Ask questions about warranties if laid on liquid screeds vs dry screeds etc 1
Adsibob Posted June 27, 2021 Posted June 27, 2021 (edited) I asked my builder which screed he is going to use, and he tells me sand and cement based screed only needs a couple of weeks to dry. We are having about 65mm worth. Is he just plain wrong about this, or Is it possible he is using some sort of additive to speed up the curing process? We are laying 600x600x20 terrazzo on top, so need to be sure it works. Edited June 27, 2021 by Adsibob
Russell griffiths Posted June 28, 2021 Posted June 28, 2021 11 hours ago, Adsibob said: I asked my builder which screed he is going to use, and he tells me sand and cement based screed only needs a couple of weeks to dry. We are having about 65mm worth. Is he just plain wrong about this, or Is it possible he is using some sort of additive to speed up the curing process? We are laying 600x600x20 terrazzo on top, so need to be sure it works. 65 days unless he’s using a modified cement product to mix it with. 1
Haylingbilly Posted June 28, 2021 Posted June 28, 2021 When you say it take 65 days to dry, how long is it until you can walk on it? Ie, how long do you need to keep people out of the screed area of your build?
Russell griffiths Posted June 28, 2021 Posted June 28, 2021 12 minutes ago, Andy brown said: When you say it take 65 days to dry, how long is it until you can walk on it? Ie, how long do you need to keep people out of the screed area of your build? 1 day liquid screed 3-7 for traditional if they have used a retarder to stop it drying to quick.
Adsibob Posted June 28, 2021 Posted June 28, 2021 How much more expensive is liquid screed than traditional?
