Hello all!
We are finally taking the first steps towards our first self-build project in a small village in Cambridgeshire. About 7 years ago we found a run-down 1950’s house sitting in a lovely 0.75-acre plot in the middle of the village conservation area. We are currently living in the old house and we have submitted a full planning application to demolish and replace the house with a larger, well insulated modern ‘barn style’ house to fit in well with the surroundings.
Our LPA took nearly 9 weeks just to validate our application (they did ask for one minor correction which was provided on the same day). The application seems to be moving forward well now with neighbours and parish council supportive.
Our Phase 1 eco survey stated ‘low potential for bat roost’ and unfortunately one pesky Pipistrelle was then spotted emerging during a follow-up dusk survey! We have now had a dawn survey and we will have to pay for bat mitigation including supervised hand stripping of the old roof tiles…
I’m planning to be very much ‘hands on’ during the build and I have already found lots of useful info on the forum. I’m sure I’ll have plenty of questions as we get underway.
  • Like 3
Welcome!  Embrace your bats!  In the not too distant future you can sit on your new patio on a warm summers evening (with a glass of wine perhaps?)  watching them flit around keeping the bugs down...
Make friends with your ecologist, as they can be like Building Control Officers: either very helpful and reasonable, or the exact opposite. One problem I had was the specification to use F1 bituminous felt. If this is specified, take care as it is not breathable so you need to ensure there is good loft ventilation, particularly tricky in parts of a pitched/vaulted ceiling. John Wayne forgot to do this and it's given me a headache.
Another thing to note is that a membrane called 'Batsafe' is not,so beware, you will be made to remove it, it is like the usual polyester breathable membranes (tangles in bats' feet and entraps them).  It's the subject of ongoing lawsuits but is still for sale to the unwary.
+1
One web site says there is currently no bat approved breathable membrane.
If you use a non breathable membrane you need either a ventilated loft (insulation on the floor of the loft) or if the insulation is at rafter level then you need a 50mm deep ventilated void under the membrane. Both needs vents at the eaves and the latter needs vents at the ridge as well.
An alternative would be to go for a so called "warm roof construction. This has all/most of the insulation above the rafters rather than between and/or below them. Caution, many builders have never built "warm roof construction" and think it just means there are rooms in the roof - not so. A proper warm roof construction needs special long fasteners to fix counter battens to the rafters through the thick insulation. If your builder claimed to understand warm roof construction ask which fasteners he prefers ?
Another alternative is SIP roof.
Thanks for the comments and bat humour!
I do quite like to watch the bats at dusk, just don’t like getting reamed for several £k before we even get started!
I hadn’t considered the potential impact upon roof construction, but I’m still waiting for the report with bat mitigation measures.
Fingers crossed it won’t be a heated two storey bat annexe ?
Definitely agree, ours was very good and reasonable. I didn’t want bat boxes in the house but preferred several in the garage/workshop  , the ecologist agreed. Planners still insisted on bat boxes built into the house as well. When I won at appeal the officer told the council they were not qualified to overrule the ecologist ?.
I was at the very naive stage when our bat mitigation stage was done, I didn't realise any of it was up for discussion. Next time, hey!
