Hilldes Posted May 13, 2021 Posted May 13, 2021 About to start fixing PIR insulation sheets across the inside of the timber frame. Need a method of ceiling the foil on the PIR to the concrete slab (will have no screed). The foil of the PIR will be taped to form the VCL. Timber frame company said they would normally prime the concrete slab with PVA, then use tape to seal this to the foil on the PIR - I'm assuming this is standard aluminium foil tape. Has anybody done this? Are there any alternative approaches for ensuring an airtight seal at this junction?
Big Jimbo Posted May 13, 2021 Posted May 13, 2021 That foil tape sticks very well to the foil on the PIR. I bet that whatever you coat the concrete floor with........That tape wont stay stuck for long.
Hilldes Posted May 14, 2021 Author Posted May 14, 2021 (edited) That would be my concern too @Big Jimbo. Does anyone have an alternate solution please? I have searched both Buildhub and googled but can’t locate a solution. This must be a relatively standard detail. Edited May 14, 2021 by Hilldes
Pete Posted May 14, 2021 Posted May 14, 2021 12 hours ago, Hilldes said: About to start fixing PIR insulation sheets across the inside of the timber frame. Need a method of ceiling the foil on the PIR to the concrete slab (will have no screed). The foil of the PIR will be taped to form the VCL. Timber frame company said they would normally prime the concrete slab with PVA, then use tape to seal this to the foil on the PIR - I'm assuming this is standard aluminium foil tape. Has anybody done this? Are there any alternative approaches for ensuring an airtight seal at this junction? This is exactly what I did. My sole plate had some adhesive + mechanical fixings. It then had adhesive/sealant between sole plate and timber frame sections. Then I primed the concrete and used the appropriate tape for wood to concrete and it is still like nobodies business 3 years on. My air test was 0.4 with a bug piece of window trim missing so it must have worked well
keith65 Posted May 14, 2021 Posted May 14, 2021 put a bead of air tight foam on the PIR then push it to the floor, but you will need to mist the concrete first with water to help the foam expand
Hilldes Posted May 14, 2021 Author Posted May 14, 2021 42 minutes ago, Pete said: This is exactly what I did. My sole plate had some adhesive + mechanical fixings. It then had adhesive/sealant between sole plate and timber frame sections. Then I primed the concrete and used the appropriate tape for wood to concrete and it is still like nobodies business 3 years on. My air test was 0.4 with a bug piece of window trim missing so it must have worked well Thanks @Pete so you effectively sealed the timber frame to the concrete floor? - Did you use foil on PIR insulation as your VCL?
Hilldes Posted May 14, 2021 Author Posted May 14, 2021 43 minutes ago, keith65 said: put a bead of air tight foam on the PIR then push it to the floor, but you will need to mist the concrete first with water to help the foam expand Thanks @keith65 by "air tight foam" do you mean regular expanding foam?
andy Posted May 14, 2021 Posted May 14, 2021 Timber frame sole plate to concrete slab sealed with this primer on concrete: https://www.greenbuildingstore.co.uk/products/pro-clima-tescon-primer-rp/ And then taped all the way around a very long permiter with this: https://www.greenbuildingstore.co.uk/products/pro-clima-tescon-vana/ Sticks like no-ones business, it's contact activated so make sure you use the blue scraper it comes with to press it down. I then had a levelling screed go down, so that tape ain't moving, ever! If you want a flexible airtight seal e.g. around soil pipe penetrations you can also use this (and tape if you want to go mad!): https://www.greenbuildingstore.co.uk/products/pro-clima-orcon-f/ 1
Hilldes Posted May 14, 2021 Author Posted May 14, 2021 Many thanks @andy, will take a look at those products
keith65 Posted May 14, 2021 Posted May 14, 2021 No you need to use an air seal foam much finer than the normal foam I got some from Toolden FM330 Pro foam air seal
A_L Posted May 14, 2021 Posted May 14, 2021 Like @andy I would go for Tescon, but this one with primerhttps://proclima.com/products/bonding-agents/edges-and-corners/tescon-profect/system-products#sub_navigation an alternative might be a non-setting (usually butyl) mastic e.g. https://www.tradebuildingproducts.co.uk/products/145-butyl-rubber-sealant?variant=39251952599193¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2020-04-21&utm_source=google&utm_medium=smart_campaign&gclid=EAIaIQobChMItOKwiL3H8AIVS-PmCh1wKwJgEAQYHCABEgJFNvD_BwE applied between the edge of the board and the slab
Pete Posted May 14, 2021 Posted May 14, 2021 13 hours ago, Hilldes said: Thanks @Pete so you effectively sealed the timber frame to the concrete floor? - Did you use foil on PIR insulation as your VCL? No, just an internal vcl as a complete barrier on its own
Hilldes Posted May 15, 2021 Author Posted May 15, 2021 Thanks @A_L like the idea of the pre-folded tape for floor/wall junctions.
