Hi all,
I am interested in a contemporary, statement front door like these:
https://camelglass.co.uk/liquid-metal-front-entrance-doors/
Initial research suggests these things are very expensive for what they are.
I wonder if anyone has any advice on the following:
1. Are they always as expensive as I have found so far (thousands rather than hundreds for a door)?
2. Is there any merit in taking a standard old timber door and seeking to attach sheet material to it, thereby achieving a similar effect?
Thanks
1. I have bought 2. Yes.
2. I doubt it.
I say that becuase of my experience of all the little bits of the door : hinges, striker plate, embedded glass,  locking mechanism - they're all vastly superior to a standard timber door.
And vastly more expensive. Vastly.
2. I doubt it.
I thought so!
Mind you, if I had a normal timber front door with normal hinges etc, and I just stuck a sheet of thin material to the front, making holes carefully for the key hole and post box, that could work?
In theory?
With lot of patience you could probably make something that, from a distance, at dusk and with a squint, looked like an aluminum door but you do really notice the difference in quality when you open and close them. The prices are painful though,
Well as a DIY nut I would make my own, buy a heavy door blank and fix rusty steel/copper/aluminium /whatever and buy decent locks and hinges (emperors new clothes spring to mind).
Your screen name wasn't @Onoff at one time was it? 'Cos if it had been, I'd say yes, you might get away with it.
Until you actually opened the door: you feel its weight, its heft, the way it goes clunk. One of ours is mostly glass - everyone comments on it. And the lady postie has seen more of me than she bargained for (or I for that matter ?) Its a feel thing as well as what it looks like.
Gotcha. though I have never encountered a proper expensive posh door, so I won't know any better! As the song says, if I hadn't seen such riches I could live with being poor!
This is my thinking precisely. I only want a solid door with no windows, so I'm only affixing one whole thin sheet to a door, or perhaps several equally sized strips, which should make it easier.
Given the low cost of 2nd hand heavy doors on ebay, and the relative low cost of sheets of various materials, I might just have a go.
Unless anyone has any suggestions for reasonably priced doors of this type?
What do you consider reasonably priced?
A decent sheet metal place could fold you two L shaped skins, each having a face and an edge. Taken a bit further you could have apertures such as for letter boxes and hinges pre cut via laser or water jet.
Less than a grand?
Now you're talking! Thats is a very interesting idea. I may even be able to place that folded sheet around a simple timber frame rather than an old door, and place insulation on the voids?
3 minutes ago, joe90 said:
I have made large front doors using blanks and plant on timber to resemble originals. Just first tinternet search https://www.doordeals.co.uk/products/external-doors/solid-external-doors/external-door-blank-(solid-core).aspx
Timber rather than steel is another idea I've considered. I quite like timber in horizontal panels.
My concern would be that whereas metal would be robust in a thin sheet, I presume timber cladding would need to be thicker?
What timber did you use, and were you please with the result?
23 minutes ago, Tony K said:
Less than a grand?
It's the sort of project that can be done on the cheap if you've a mate who runs a fabrication company etc or you can slip it through with another job. You need to be careful at the junction where the two 'Ls" meet so as to avoid sharp edges and corners etc.
Well, I don't have such a mate, but even commercially the material itself doesn't seem too expensive?
It was an OSB core with veneer either side, trimmed and oak plant on,s all round, mouldings glued and pinned on to replicate panels and painted (by the customer). It was an oversized Victorian front door I was replacing due to rot. Customer really pleased. Oh and heavy duty bearing hinges to cope with the weight. (Was a few years ago thinking about it ?).
We spent a *lot* on a RK door but it was passive standard, thermally broken with all the seals and gaskets etc. Amazing hinges allow door to open 180o (if there hadn't' been a wall in the way, doh) and fingerprint sensor which has worked flawlessly for 5 years - no keys for the kids to loose.
I really like our RK door but I just can't get the day latch to work. ie. if you close the door it's always locked from the outside, no matter how I set the thumb turn on the inside. I do need to go back to them, again.
28 minutes ago, Bitpipe said:
fingerprint sensor which has worked flawlessly for 5 years...
Now we know the truth. You've never mixed concrete and thus lost yer fingerprints have ya? Ha! Gottcha! Busted!
That's the kind of thing I had imagined. As you say, I can buy a blank door and add to it.
I presume I would then ask a chippy to produce a frame that fits the resultant door rather than buying a standard one?
Yes, but you could plant on to a standard frame to make up the extra thickness of the door blank, just make sure it’s glued well ?.
Right, so buy a standard blank door with frame to match, then customise both?
Yep, I've rubbed them away moving blocks, digging holes etc. However I always carry a key, maybe use once a few months. Kids not mixing much concrete these days.
This is what I think too.
If you find a great fabricator and are able to give proper consideration to detailing, I reckon something amazing could be diy'd.
Wouldn't be easy, but it could be exceptionally unique.
Cant say the idea appeals to me though. Dont see the point.
Edited by Makeitstop
