We'll have three wet rooms in the house all with walk in showers. The guy at the bathroom place was trying to sell me a £600 insulated board based kit for a shower...
All floors are concrete with 75-100mm screed.
Would I use a paint on system for the entire room:https://www.screwfix.com/p/mapei-shower-waterproofing-kit/78484?tc=QB4&ds_kid=92700046986170840&ds_rl=1241687&ds_rl=1245250&ds_rl=1245725&ds_rl=1245250&gclid=CjwKCAjw7diEBhB-EiwAskVi1wo7ZYuc-PnMlNmB5d8NfO_wMbxDTurWZ0gQpwU0JRt_6Uy7Uu8aQRoCqSYQAvD_BwE&gclsrc=aw.ds
or so I need something more for the shower and bath areas, like this?
https://www.tradewetrooms.com/impey-waterguard-wetroom-wall-floor-membrane-kit-10m2-copy/?gclid=CjwKCAjw7diEBhB-EiwAskVi1xHEkQaaNaaAJvlLFoa9Oa0llYXny--tP3a0DHAJP9c5yZwTC7MVERoCBo8QAvD_BwE
Anything else to consider?
Edited by Conor
When I tanked our 3 wet rooms over 3 years ago now I used the Mapei kit in 2, easy to use and worked a treat. In the 3rd I used the adhesive membrane, what a dog to apply and not quite so successful as we have the grout around the trap breaking up, I think because the membrane was not stuck down so well.
So I would definitely recommend the Mapei.
15 minutes ago, James94 said:
What have you done for the shower area for fall and waste?
Regards. James
Geberit wall drain...you asked! ?
I left a section out of the floor:
SAM_3354
The yellow bit is a removable, protective, temporary cover:
20170815_213119
SAM_5788
The cover comes off to reveal a folded up membrane:
20180308_183956
Had to use s 2"/50mm euro adapter on the waste:
20170827_102615
Starting to foam in:
20170828_131057
I made a metal frame to falls:
20180328_182638
IMG_20180330_160739735
A special, heavy on the SBR, 10mm pea shingle concrete mix:
20180401_153630
Tamped to falls:
20180401_190603
The membrane folds out and gets tanked in:
20180614_181948
20180614_182331
Novel and great fun to do. There's a good few install videos:
