rh2205 Posted May 5, 2021 Posted May 5, 2021 (edited) Hello, Bt came out and jointed their cable to our cat 6 runs in the middle of the house. Only issue is they just left the jointed cable completely exposed & so long we cannot roll it up to fit it in the box with a cover plate on. Any other type of cover plate I can get to hide this jointed cable in? It was just a typical single switch type box would need something deeper than a typical cover plate. Didn’t even think to check he’d finished off that area where the cable comes in properly before he left because the internet was working & the bt box in the middle of the house looked completely fine! Edited May 5, 2021 by rh2205
PeterW Posted May 5, 2021 Posted May 5, 2021 How deep is the back box..? I would cut it back - both sides - and then use a very quick/cheap punch down connector in the box such as this https://www.ebay.co.uk/itm/CAT5e-6-IDC-4-Pair-8-Way-Junction-Box-8P8C-Inline-Cable-Coupler-Terminal-Socket-/224041015912?_trksid=p2349624.m46890.l49286
Bitpipe Posted May 5, 2021 Posted May 5, 2021 23 minutes ago, PeterW said: How deep is the back box..? I would cut it back - both sides - and then use a very quick/cheap punch down connector in the box such as this https://www.ebay.co.uk/itm/CAT5e-6-IDC-4-Pair-8-Way-Junction-Box-8P8C-Inline-Cable-Coupler-Terminal-Socket-/224041015912?_trksid=p2349624.m46890.l49286 Jelly crimps are even cheaper £2 for 20. Still surprised that they did not terminate to a BT Master socket. I get that it works now but would be concerned if an issue occurred in the future and the next OR engineer to visit threw their hands up !
ProDave Posted May 5, 2021 Posted May 5, 2021 I would just buy a BT NTE5 master socket and fit that. What did they fit on the other end of your Cat6 cable?
rh2205 Posted May 5, 2021 Author Posted May 5, 2021 (edited) @ProDave They fitted a bt master socket at the other end, obviously I did wonder whether another bt master socket on the jointed section would be the easiest way to conceal ? Edited May 5, 2021 by rh2205
ProDave Posted May 5, 2021 Posted May 5, 2021 21 minutes ago, rh2205 said: @ProDave They fitted a bt master socket at the other end, obviously I did wonder whether another bt master socket on the jointed section would be the easiest way to conceal ? I would put a master where your joint is, and a slave at the other end. Like others, if there is ever a fault, and OR come to the property, you don't want them blaming your CAT6 cable as the "problem" so best to have a clean demarcation in the form of an NTE5 where their cable ends.
ProDave Posted May 5, 2021 Posted May 5, 2021 Also, as a matter of personal opinion, I would buy the old NTE5A, much more robust and versatile. I hate the current NTE5C so much harder to terminate and that silly clip on front plate is hard to unclip if the socket is close to a corner and easy to break trying. You can also get a filtered plug in for the NTE5A to separate landline and broadband, so extension telephone wiring should not affect your broadband performance.
rh2205 Posted May 5, 2021 Author Posted May 5, 2021 Thanks everyone, I will just get an old school master socket I prefer the look, not too worried about telephone line, we’re from the generation that’s only ever had a mobile phone, doubt we’ll use the cat 6 sockets in the rooms either it was only a back up in case WiFi sucked or we found a reason to play some online games by which point everything will be coming in from the sky wirelessly anyway I suspect ?
