Dan F Posted February 9, 2021 Posted February 9, 2021 Has anyone come across any software for modelling different options for acoustic ceilings? Or, has anyone had any sucess with using https://i-simpa.ifsttar.fr/ I'm looking at a few options for a ground floor ceiling and would ideally I'd like to be able to model the options, before unnecesarily overcomplicating things. 1) 2 x SB with CasoLine ML. Need to box out steels seperatly in fireboard. Penetrations for downlighters required. 2) Fireboard or 2xSB fixed directly to the bottom of joists. Additional layer of PB for sacrifical ceiling for lighting on hangers. 3) Fireboard or 2xSB fixed to the bottom of joists with reslient layer between joists and PB. Additional layer of PB for sacrifical ceiling for lighting on hangers 4) Fireboard or 2xSB fixed on resilient bars bars. Additional layer of PB for sacrifical ceiling for lighting on hangers
SteamyTea Posted February 9, 2021 Posted February 9, 2021 I think LISA does acoustics. https://lisafea.com/
Temp Posted February 9, 2021 Posted February 9, 2021 From what I've read building two separate walls/floors that aren't connected and both have mass is the way to go. Anything that connects one side to the other is a potential transmission route. This sort of thing... PS: My son has just started a degree in Acoustical Engineering so ask again in three years and he might tell me its all wrong ? 1
Moonshine Posted February 10, 2021 Posted February 10, 2021 @Dan F why the sacrificial plaster board, just because of down lighters? 8 hours ago, Temp said: My son has just started a degree in Acoustical Engineering South bank or southampton?
Dan F Posted February 10, 2021 Author Posted February 10, 2021 (edited) 2 hours ago, Moonshine said: @Dan F why the sacrificial plaster board, just because of down Yes, plus motion sensors etc. We also have recessed lighting tracks in some areas as well a couple of areas with some receased paneling. Given this, a continius layer of board(s) for both fire+acoustics just seemed like a good idea. If we do this though, the question is what to do above it, as: - Fixing the continous pb/fb direct to joists is almost certainly a bad idea. - But, using resilient bars and 2xSB may we overkill and present somewhat of a practical issue regarding the gypframe hangers. Edited February 10, 2021 by Dan F
Temp Posted February 10, 2021 Posted February 10, 2021 6 hours ago, Moonshine said: @Dan F why the sacrificial plaster board, just because of down lighters? South bank or southampton? Southampton. Although he's been at home since Christmas.
Carrerahill Posted February 10, 2021 Posted February 10, 2021 15 hours ago, Temp said: From what I've read building two separate walls/floors that aren't connected and both have mass is the way to go. Anything that connects one side to the other is a potential transmission route. This sort of thing... PS: My son has just started a degree in Acoustical Engineering so ask again in three years and he might tell me its all wrong ? This is how I did the walls in my living room. Offset studs and acoustic rockwool.
Temp Posted February 11, 2021 Posted February 11, 2021 20 hours ago, Moonshine said: South bank or southampton? If you know the courses, is that your occupation?
Moonshine Posted February 11, 2021 Posted February 11, 2021 (edited) 2 hours ago, Temp said: If you know the courses, is that your occupation? Yep, though I did BSc and a MSc in acoustics at a different uni, so I'm a scientist, rather than an engineer ? I know people that went to Southampton and it's a good course, real shame he cant get into the labs at the moment Edited February 11, 2021 by Moonshine 1
SteamyTea Posted February 11, 2021 Posted February 11, 2021 (edited) 21 minutes ago, Moonshine said: so I'm a scientist, rather than an engineer Best way. Is there, basically, only two ways to reduce noise. Absorption via mass and deflection/interference via rigidity? I read this when it came out (2002). It was a bit close to April 1 for my liking, but always remembered it. Sculpted sound 23 March 2002 By Philip Ball PUBLIC sculpture is all very impressive to look at, but what use is it? It just sits there providing a perch for pigeons and a backdrop for tourists’ photos. But a few years ago, Francisco Meseguer of the Institute of Materials Science in Madrid found an unexpected answer. He discovered that a minimalist sculpture on display in Madrid can block out sound. Erect such barriers throughout a noisy city or along the sides of a motorway and the tumultuous modern world might not only become a quieter place, but a more attractive one too. The structure he stumbled across is called a sonic crystal because it scatters sound waves from a periodic array of “atoms”—anything from glass spheres to metal rods. Unlike conventional, solid sound barriers, sonic crystals are mostly empty space. And they’re a lot easier on the eye, too. Now Meseguer and his colleagues have shown that these structures can do a lot more than simply block sound. Sonic crystals can shape and manipulate sound as if it were putty, reflecting, bending and filtering it in unexpected ways. They might even transform unpleasant environmental noise into something far more soothing. And the Spanish team hopes to make similar structures for controlling other kinds of unwanted vibrations. In the grandest and, by their own admission, the craziest of such schemes, they think it might be possible to build gigantic sonic crystals that dampen seismic waves and protect buildings from earthquake damage. Meseguer first stumbled across sonic crystals while he was working on tiny structures called photonic crystals. Developed in the 1980s, these can be used to manipulate light, and are now being turned into devices such as lenses and fibres for all kinds of optical communications technology (New Scientist, 12 June 1999, p 36). One of the simplest forms of photonic crystal is simply a block of silica with a regular array of holes drilled in it. The difference in refractive index between the silica and the air in each hole means that light is scattered at the boundary where they meet. Make the distance between the holes about the same as the wavelength of light shining on it and the scattered photons interfere destructively. Simply put, the crystal blocks light in that range of wavelengths. It has a “photonic band gap”. Nowadays, photonic crystals are often made by allowing microscopic glass beads to settle out of a suspension into organised lattices called colloidal crystals. Structures like these form in nature too. The iridescent appearance of opal, for instance, comes from the light-scattering properties of the tiny silica spheres that make up its lattice. For photonic crystals with band gaps in the visible region of the spectrum, the holes or spheres must be a few hundred nanometres apart. But in 1995, while Meseguer was chatting with acoustics expert Jaime Llinares of the Polytechnic University of Valencia (UPV), they realised that if these structures were scaled up to centimetre dimensions—corresponding to the wavelength of sound—they might be able to create an acoustic analogue of a photonic crystal. Inside their imaginary sonic crystal, the scientists reasoned, sound waves should bounce off the “atoms” in such a way that the waves interfere destructively, cancelling out the oscillations in the air. Llinares suspected that some form of sonic crystal might already exist. He remembered that on the UPV campus there was a sculpture by the Spanish minimalist artist Eusebio Sempere, made from an array of vertical metal bars of various lengths, of about the right thickness and spacing, like a set of surreal organ pipes. Could this block sounds? To find out, they placed a loudspeaker on one side of the sculpture and a microphone on the other. The speaker broadcast white noise through the sculpture, but when they measured the intensity of the sound on the other side, there was no sign of a band gap. The problem, they decided, was that the sculpture was made of hollow metal cylinders which resonated like organ pipes. Since some of the pipes were very short—about 10 centimetres, the same as the separation between pipes—they were resonating at frequencies inside the expected acoustic band gap, and this vibration masked the gap. Fortunately, Sempere had constructed a similar, but larger bar sculpture, on display at the Juan March Foundation in Madrid. In this outdoor sculpture the pipes are up to three metres long. The two researchers set off with their loudspeaker and mic to try again. This time they found that the sculpture actually blocked out sound. It wasn’t a perfect “crystal”, however, so the acoustic band gap was rather leaky. Worse still, the measurements were muddied by noise reflected from nearby buildings. To improve their data, the researchers decided to make their own minimalist sculptures by hanging cylinders of stainless steel or wood from a frame. This created a regular forest of bars that wouldn’t look out of place in any modern art gallery. In 1998, instead of entering it for the Turner Prize, they mounted their crystal in an echo-free acoustic chamber and began experiments to measure how sound travelled through it. Their data revealed that the structure strongly suppressed sound waves in the audible range, at frequencies between 1400 and 1700 hertz. At last they had clear evidence of a sonic crystal. Just months ago, the team also revealed how sonic crystals could be used not only to block sound but also to manipulate it (Physical Review Letters, vol 88, p 023902). At frequencies below the acoustic gap, sonic crystals are transparent to sound. But they don’t let sound waves pass unscathed. Just as light is bent by refraction when it passes from air into glass, so sound waves are bent when they pass into a sonic crystal. The researchers realised that they could use this to create a lens that focuses sound. The lens they built is a convex array of cylinders (see Diagram). Put a sound source on one side and the lens focuses the sound waves on the far side. The focus is rather blurred, however, partly because the surface of the lens is quite rough—you can’t make a smoothly convex surface from a small number of cylinders, the structure is just too “grainy”. It’s like trying to make a lens from a handful of atoms. They also built an acoustic analogue of another common optical device: a Fabry-Pérot interferometer. This is made from a stack of thin films that create interference patterns when light reflects off each layer. The acoustic version is simply a “slab” of sonic crystal, with rows of cylinders hanging parallel to the flat faces of the slab. Fabry-Pérot devices are commonly used in microwave technology as filters. But Jose Sánchez-Dehesa, a physicist at the University of Madrid who worked on the project, admits that it is not yet obvious where the team’s sonic analogues of lenses and filters might be used, because they are so large. The basic sonic crystal, however, which blocks sound waves within a tunable frequency band, might find all sorts of uses. Imagine a barrier made from crystals that are designed to have all the aesthetic qualities of a Sempere sculpture but which cuts out traffic noise on the far side. “Sound-deadening barriers could be an interesting application of our findings,” says Sánchez-Dehesa. They would be more expensive than regular barriers, because they’re more elaborate, but he argues that in residential areas they would be a definite improvement on “ugly concrete panels”. His colleague Juan Vicente Sánchez-Pérez at UPV is now planning to patent a prototype sound barrier based on an array of cylinders. Not everyone is convinced that sonic crystals offer any real advantages over conventional materials. Victor Krylov, an acoustics specialist at Loughborough University, believes that the sound barriers currently used along motorways and railways are at least as effective, and cheaper too. Certainly, the need to space the cylinders at a distance of about one wavelength is a drawback, because it means that sound-proofing structures have to be big and thick. In 2000, however, Ping Sheng and his colleagues at Hong Kong University in Kowloon showed that there might be a way around this. They made sonic crystals from a cubic array of lead balls just one centimetre across, each ball coated with silicone rubber and glued into the array with epoxy resin. It was a kind of giant sonic opal. This structure displayed acoustic band gaps for sounds with wavelengths of around 1 metre and 25 centimetres—wavelengths that are hundreds of times as large as the spacing of the sound scatterers. They attributed this unexpected effect to the rubber-coated balls resonating at specific frequencies—they vibrate like heavy masses attached to springs. Sheng’s colleague Che Ting Chan says the Hong Kong team are now making sonic crystals that absorb sound. They believe sonic crystals like these could be used to block sonar signals at sea, for instance. Make submarine hulls from this stuff and they would be invisible to sonar from ships or other subs. Alternatively, say Peter Matic and Narendra Batra from the Naval Research Laboratory in Washington DC, the acoustic gap might be useful for filtering out particular frequencies generated by heavy machinery. They aim to design multifunctional materials which can be stiff and tough as well as providing acoustic shielding. Build them into a ship’s hull and you might be able to silence the sounds of the vessel’s engine, making it harder for submarines to detect. Sánchez-Dehesa thinks it might even be possible to design barriers that change the quality of the sound as it passes through. Just as photonic crystals can filter the wavelength of light passing through, it might be possible to design a sonic crystal so that objectionable noise passing through it becomes more tolerable—even pleasant. “My goal is to look for a panel based on a sonic crystal that could transform bad sound on one side, like traffic noise, to good sound on the opposite side, like the sound of the trees or ocean waves.” If that sounds daring, it is nothing compared to another idea they are toying with. Since these materials work for light and sound waves, it should be possible to build a structure that can block or transform other kinds of wave—including seismic waves in the ground. Just as you can make a slab of material impermeable to light by perforating it with a lattice of tiny holes, so you might make the Earth’s crust impenetrable for seismic waves by drilling an array of huge holes in it. Surround a city with such a lattice, and you could shield it from earthquakes. “If seismic shielding could achieve an attenuation of two points on the Richter scale [a hundredfold reduction in energy], it would be great,” Meseguer enthuses. To test the feasibility of the idea, in 1999 Meseguer and his colleagues drilled two vertical lattices—one triangular and the other honeycomb-shaped—in a bed of marble in a local quarry. Each hole in these lattices was 6 centimetres across, 160 centimetres deep and separated from its neighbours by 14 centimetres. Then they created vibrations by dropping a steel ball bearing onto the quarry floor, and used sensors to measure how the vibrations passed through the lattices of holes. Both lattices significantly damped down the vibrations. However, to protect against real seismic waves, the holes would have to be hundreds of metres across and at least a kilometre deep. “It is clear that such a proposal is not feasible yet,” confesses Sánchez-Dehesa. “But you can protect an isolated building.” Used in this more modest way, underground “ring fences” of seismic crystals could make labs or buildings immune to vibrations such as those from passing trucks. This could be very useful, since some high-precision instruments—scanning probe microscopes for studying structure at the atomic scale, for example—are very sensitive to disturbance. Meseguer has already started looking at the practicalities of such a system. And who knows, one day these giant structures could become art in their own right. A sacred bird’s voice seems to be trapped in the very stone of the Mayan Pyramid of Kukulkan at Chichén Itzá, surrounded by the jungles of the Yucatán Peninsula in Mexico. Stand at the foot of one of the stairways that climb the outer walls, clap your hands and a chirp rings back at you from the stone surface. According to David Lubman, an acoustic consultant based in California, this is the sound of the quetzal bird, the spirit of the Maya incarnated in their plumed serpent god Quetzalcóatl. Lubman claims that it takes only a little imagination to hear in the curious echo from Kukulkan’s staircases the sound of the quetzal as it would have been heard by a Maya in the Peruvian cloud forest. This, says Jose Sánchez-Dehesa, may be an example of Mayan acoustic engineering. Architects have designed buildings since ancient times to generate and exploit particular acoustic effects, such as the whispering gallery of St Paul’s Cathedral in London. But this is engineering of a particularly sophisticated kind: for the Kukulkan staircases, with their periodic array of scattering surfaces, have many of the characteristic features of a sonic crystal. Could the Mayans really have known the secret of sonic crystals as long as 900 years ago? “I think the answer is yes,” says Francisco Meseguer. Sánchez-Dehesa agrees: “We can say that the Maya are the first people to harvest sound by making a sonic crystal.” And he hopes to prove it with a series of experiments at the pyramid. We may soon know whether the quetzal bird sings at Chichén Itzá by chance or design. Edited February 11, 2021 by SteamyTea
Moonshine Posted February 11, 2021 Posted February 11, 2021 28 minutes ago, SteamyTea said: Best way. Is there, basically, only two ways to reduce noise. Absorption via mass and deflection/interference via rigidity? Mainly yes, but it is mass that reflects the sound, and porous materials that absorb the sound by dissipating sound energy as heat. The amount of reflection and absorption which occurs depends on the physical properties of the materials and the frequency / wavelength of the sound.
SteamyTea Posted February 11, 2021 Posted February 11, 2021 1 minute ago, Moonshine said: Mainly yes, but it is mass that reflects the sound, and porous materials that absorb the sound by dissipating sound energy as heat. Yes, it was early. It is why they cover submarines in rubber, so they heat up when pinged I think.
Dan F Posted February 11, 2021 Author Posted February 11, 2021 12 hours ago, Moonshine said: Yep, though I did BSc and a MSc in acoustics at a different uni, so I'm a scientist, rather than an engineer ? Any scientific thoughts on the four options I mentioned? Problem with 3) is you still need to screw PB to joists. I assumed 4) was best, just concerned it might be overkill vs. 1) if the downlighter/speaker penetrations etc. aren't actually going to be that significant. I've played around with DIALux which is free and models lighting and it was fairly build rooms, import photometric data for fittings and run a model. I was hoping there might be something similair, with a library of materials, might exists for acoustics, but not found anything easy to use..
Moonshine Posted February 11, 2021 Posted February 11, 2021 4 minutes ago, Dan F said: Any scientific thoughts on the four options I mentioned? Problem with 3) is you still need to screw PB to joists. I assumed 4) was best, just concerned it might be overkill vs. 1) if the downlighter/speaker penetrations etc. aren't actually going to be that significant. I've played around with DIALux which is free and models lighting and it was fairly build rooms, import photometric data for fittings and run a model. I was hoping there might be something similair, with a library of materials, might exists for acoustics, but not found anything easy to use.. There are a couple of modelling software such as insul and Bastian, though I don't trust them and prefer to make a judgement of similar constructions with test data. I will take a look when I have a bit of time, though how many down lighters are you going to have. Robust details of party floors recommend a max of one per 2 m2 not to undermine the performance. If you are going to use more you could provide acoustic hoods.
puntloos Posted March 30, 2021 Posted March 30, 2021 ... hey @moonshine - any updates? I find myself in a similar situation where as someone told me recently - if you add the word 'acoustic' to something the price jumps by 30% for the same thing. But in general: - When I'm trying to find buildup suggestions for internal walls I tend to get drawings for stud walls (in particular stud-air-stud), but no block walls of the same composition. Is block-air-block worse or better than stud-based? - Materials to apply to walls? - Do you even want to absorb? Except for cinemas you don't want dead rooms either! - Ceiling buildup? Would love some pointers where to research or advice. Ideally nothing with 'acoustic' in the title
Moonshine Posted March 31, 2021 Posted March 31, 2021 7 hours ago, puntloos said: ... hey @moonshine - any updates? I find myself in a similar situation where as someone told me recently - if you add the word 'acoustic' to something the price jumps by 30% for the same thing. But in general: - When I'm trying to find buildup suggestions for internal walls I tend to get drawings for stud walls (in particular stud-air-stud), but no block walls of the same composition. Is block-air-block worse or better than stud-based? - Materials to apply to walls? - Do you even want to absorb? Except for cinemas you don't want dead rooms either! - Ceiling buildup? Would love some pointers where to research or advice. Ideally nothing with 'acoustic' in the title I ended up giving @Dan F some advice via PM. Acoustic can mean cost increases, sometimes justified. 'Acoustic' plasterboard is really just denser plasterboard it doesn't have any magical acoustic properties other than being denser than standard plasterboard. Block internal walls aren't really standard, though if you are willing to soak up the expense and extra room then they can out perform stud work, especially at low frequencies as they have greater mass. I have never come across someone using a cavity masonry wall for internal walls, they are primarily used on party walls. If you really want to go for block, you could use something like block with a independent stud (metal / wood) wall with insulation in the cavity. Stud or masonry? for what aim? No real need to as in a domestic setting carpets and soft furnishings will usually be fine. For internal floors it depends how much sound insulation you want.
puntloos Posted March 31, 2021 Posted March 31, 2021 5 hours ago, Moonshine said: I ended up giving @Dan F some advice via PM. Acoustic can mean cost increases, sometimes justified. 'Acoustic' plasterboard is really just denser plasterboard it doesn't have any magical acoustic properties other than being denser than standard plasterboard. Block internal walls aren't really standard, though if you are willing to soak up the expense and extra room then they can out perform stud work, especially at low frequencies as they have greater mass. I have never come across someone using a cavity masonry wall for internal walls, they are primarily used on party walls. If you really want to go for block, you could use something like block with a independent stud (metal / wood) wall with insulation in the cavity. Well, in our current design (new build) my architect already left the downstairs walls to be 200mm, so I am just wondering whatever is the best option there. I don't necessarily need to get the maximum-at-any-cost but e.g. 75 block - 50 "insulation"(open for suggestions?) - 75 block might work? But if it is block, am I making my life harder wrt wiring/services - power sockets, lamps, etc etc? 5 hours ago, Moonshine said: Stud or masonry? for what aim? Not sure what you mean? But yes just 'standard' walls are the default idea, but the very outer layer, I think there are things such as 'absorbing paint' or (purely theoretical, I doubt it'd look or feel nice) I could apply a layer of cork etc. 5 hours ago, Moonshine said: No real need to as in a domestic setting carpets and soft furnishings will usually be fine. Well the livingroom is fairly large (8x5) so the floor probably has to be reasonably absorbent but also allow UFH- as you said, carpet would work but I don't think we want that. The aesthetic of tiles or maybe even hardwood - so basically something hard & fairly shiny - would be our preference but of course that echoes and is also not great to hit your head on. My current default is amtico since I understand it has somewhat good audio properties and somewhat good UFH properties but happy to have other materials suggested 5 hours ago, Moonshine said: For internal floors it depends how much sound insulation you want. 2 use cases: 1/ Someone playing a movie in the main livingroom downstairs, sleeping upstairs. It will go LOUD. (I have a serious cinema system, and a male child who might be tempted to turn it up to 11 to impress friends) 2/ Kid bedroom and parent bedrooms should not be heard, and should not hear the outside.
SteamyTea Posted March 31, 2021 Posted March 31, 2021 (edited) You can get floor tiles that absorb sound. They used them in Milton Keynes shopping centre to stop that swimming pool echo. Can you use brick or block wall with plasterboard fitted onto resilience bars. You get a small service cavity that way. Edited March 31, 2021 by SteamyTea
