SteamyTea Posted August 11, 2021 Share Posted August 11, 2021 1 hour ago, keith65 said: And yes Cornwall last stop before nowhere Apart from The Islands of Scilly. Link to comment Share on other sites More sharing options...
keith65 Posted August 12, 2021 Author Share Posted August 12, 2021 Very true Link to comment Share on other sites More sharing options...
keith65 Posted April 21, 2022 Author Share Posted April 21, 2022 Time has seamed to have gone so quickly and work has not keep up. I thought I would have finished a long time ago but still working through, but some light at the end of the tunnel. Have managed to make the stairs and first fix pluming and electrician has finished first fix then all the plaster boarding and skimming done what a Christmas. My arms did not know what hit them. Now onto second fix so have fitted the kitchen and bathroom out and put in the feature wall behind stairs. Plumbing all finished just need to get the SAHP hot water system commissioned, and second fix electrics has started and also have started to lay the LVT flooring. I used the Eger flooring with the protective covering and did not realise you can`t glue the flooring straight on top so have hade to lay 6mm ply down first but as i am using it on the stairs have also had to add to stair treads to keep the rise the same. Link to comment Share on other sites More sharing options...
Surfiejim Posted September 16, 2022 Share Posted September 16, 2022 Hi Keith. Thanks for documenting your Isotex build. I'm down the road in St. Agnes and hope to start a similar project very soon. I'm interested in the insulated raft foundations. Did you find this method reduced costs over all? Link to comment Share on other sites More sharing options...
Nickfromwales Posted September 17, 2022 Share Posted September 17, 2022 On 16/09/2022 at 18:34, Jamie Kent said: I'm interested in the insulated raft foundations. Did you find this method reduced costs over all? The insulated rafts are more about low energy / high performance, ergo the reduced heating costs for the life of the dwelling is usually the where most attraction to this type of foundation comes from. Link to comment Share on other sites More sharing options...
GSN Posted October 22, 2023 Share Posted October 22, 2023 Hi Keith, I was reading up on your build as currently in the process with an architect of designing a fairly large single storey ~190sqm “outhouse”, in the garden (new build) as well as an extension to our existing house too. Plans are to be finalised and sent to planning but I recently attended the Grand Designs show at the NEC and came across Isotex which interested me greatly as an alternative way to build. I will be in contact with one of the Italian owners whom I met at the show about it all but wondered whether you had any final thoughts about it all, whether you would use it again as a build method, whether anything that you had not considered before about the build changed your thinking and whether you would do anything differently. I am grateful for your time and I hope you are enjoying your build otherwise. BW Nags Link to comment Share on other sites More sharing options...
BotusBuild Posted October 23, 2023 Share Posted October 23, 2023 On 07/04/2021 at 07:47, keith65 said: The second pour was a couple of weeks later so drekley as they say. Coming to this late. my two pours in SE Cornwall were about 12 months apart. Very drekley 🙂 Link to comment Share on other sites More sharing options...
Chanmenie Posted October 23, 2023 Share Posted October 23, 2023 20 hours ago, GSN said: Hi Keith, I was reading up on your build as currently in the process with an architect of designing a fairly large single storey ~190sqm “outhouse”, in the garden (new build) as well as an extension to our existing house too. Plans are to be finalised and sent to planning but I recently attended the Grand Designs show at the NEC and came across Isotex which interested me greatly as an alternative way to build. I will be in contact with one of the Italian owners whom I met at the show about it all but wondered whether you had any final thoughts about it all, whether you would use it again as a build method, whether anything that you had not considered before about the build changed your thinking and whether you would do anything differently. I am grateful for your time and I hope you are enjoying your build otherwise. BW Nags Have you looked at the EPS ICF products ? I was going to build with Isotex but having been ripped off by Insulhub, and not wanting to pay the high delivery costs from Italy I looked at alternatives, I have now built with an EPS bock manufactured in the UK, which I believe is a superior product, in terms of insulation properties and ease of airtightness Link to comment Share on other sites More sharing options...
