SteamyTea Posted January 24, 2017 Posted January 24, 2017 (edited) Does anyone know of a cheap way to do this with a Raspberry Pi. All I want to know is when a pump is on or off, I don't need to know the current or the voltage. I am thinking that I could use a contactor, wired in parallel with the pump, and just sense when it is closed with a GPIO ports/pin. It would be nicer to use a non-invasive method such as a CT clamp, but not too sure how to set that up as a simple detector. Thoughts anyone? Edited January 24, 2017 by SteamyTea
Guest Alphonsox Posted January 24, 2017 Posted January 24, 2017 How about a neon or LED across the switched supply and a light sensor ?
SteamyTea Posted January 24, 2017 Author Posted January 24, 2017 I had thought of that, but I can get a relay for a tenner, and it should be pretty easy to wire in (not actually seen the pump yet). An alternative is a small PSU that can drop down to 3VDC and sense that voltage. Not sure how to wire it into the Raspberry Pi as it will not be the same as the unit powering the Raspberry Pi. Maybe connect all the neutrals together.
Onoff Posted January 24, 2017 Posted January 24, 2017 http://m.ebay.co.uk/itm/142228782611?_trksid=p2141725.m3641.l6368
Steptoe Posted January 24, 2017 Posted January 24, 2017 You could alternatively for a flow sensor on the pipework , ?
Guest Alphonsox Posted January 24, 2017 Posted January 24, 2017 1 hour ago, Steptoe said: You could alternatively for a flow sensor on the pipework , ? Just pointed Terry at one of these on another thread http://www.ebay.co.uk/itm/Flowmeter-Switch-Pulsed-Water-Beer-Flow-Meter-Sensor-1-2-/400713718471?hash=item5d4c661ac7:g:WkUAAOSwNSxVRftI Should directly interface to the Pi GPIO
Steptoe Posted January 24, 2017 Posted January 24, 2017 45 minutes ago, Alphonsox said: Just pointed Terry at one of these on another thread http://www.ebay.co.uk/itm/Flowmeter-Switch-Pulsed-Water-Beer-Flow-Meter-Sensor-1-2-/400713718471?hash=item5d4c661ac7:g:WkUAAOSwNSxVRftI Should directly interface to the Pi GPIO It would indeed, Good find,
PeterW Posted January 24, 2017 Posted January 24, 2017 Just check its WRAS compliant as it may be food safe but that won't count ..! But as @JSHarris says, will they check ..?!
TerryE Posted January 25, 2017 Posted January 25, 2017 Why not just an accelerometer to detect the vibration / hum whilst running. Then you don't need to touch the mains voltage.
Steptoe Posted January 25, 2017 Posted January 25, 2017 Thought about this, The easiest way would simply be a relay wired I'm parallel to the pump, with the outputs going to the RPi GPIO That's the simpilest method, and no complicates code or anything else for the Pi Exactly as you said in the OP @SteamyTea
