59 minutes ago, Mr Punter said:
Mug!  Cancel the order and split the winnings with me for my fine advice.
Sods Law I put a small one in and they'll want a bigger one for something else. Something else to come off the tax bill at least.
Edited by Onoff
Got the hatch in this morning. If that's not good enough access I don't know what is. I can get up through there on a set of steps. I was making too much dust I thought with the multi tool, so resorted to a pad saw. Painted the cut edges with some D4 and left to dry. The FlipFix hatch is a doddle to fit:
IMG_20201202_195349750
IMG_20201206_124615798
20201206_130042
I filled where some old pipes went through with intumescent foam.
20201206_125210
Shot above the bathroom:
20201206_125221
I'll get BG back in now.
Edit: There was some crap up there in the vicinity of the hatch, sawdust, bits of copper pipe and pb. That plus loads of bits of broken brick. Vacuumed it all away and left clean & tidy.
Edited by Onoff
  • Like 2
You only needed a small inspection cover but this will give you the benefit of being able to send up a street urchin should you wish to give the rest of the brickwork a coat of paint!
  • Haha 1
Or an extra room to rent
  • Haha 1
Update: BG coming on 18th Dec. Rang them on the 7th, day after fitting the hatch. Call centre in South Africa by the sounds of things. Only other date was the 24th or the New Year.
  • 11 months later...
? I put a hatch in for BG to inspect the flue.
The BG engineer who came last decided it was the "loft". Said on the lines it could be a problem if you were clambering about in the loft and knocked the flue. Forget for a minute you can't get in there at all easily, the space above the bathroom extension, because of the flue.
20211214_190011
20211214_190511
20211214_190552
Whatever I'll strap it up to the wall behind and roof joists above.
Edited by Onoff
