geoffdg Posted November 15, 2020 Posted November 15, 2020 Hi all, Can anyone tell me what the distance from the wall to the centre of the waste pipes would be for wc (would probably be a close coupled), hand basin and sink. Just trying to figure out out to get the position right as they come up through the raft Thanks, Geoff
joe90 Posted November 15, 2020 Posted November 15, 2020 (edited) This is difficult to get right, I got mine fairly close. I asked the plasterer how thick his scim was, put the toilet together with waste pipe and did the maths. I did the same with basins etc. Different toilet connectors have slightly different dimensions so get the kit together and measure it. Edited November 15, 2020 by joe90
Oz07 Posted November 15, 2020 Posted November 15, 2020 Around an inch off the finished wall usually I think. @Nickfromwales?
PeterW Posted November 15, 2020 Posted November 15, 2020 19 minutes ago, geoffdg said: Can anyone tell me what the distance from the wall to the centre of the waste pipes would be for wc 100mm to the centre assuming you are using board on dot and dab which adds ~25mm to the blockwork.
Temp Posted November 15, 2020 Posted November 15, 2020 Main thing is not to make it too close. If its a bit further out you can always batten the wall before plaster boarding.
