Jilly Posted October 30, 2020 Posted October 30, 2020 In my ASHP research, I spoke to a friend who recently built a garage with flat over, heated by what he told me was an ASHP. I went to have a look, and saw a Mitsubishi unit on the outside wall and an air heating unit thing directly opposite inside the building, which, in this well insulated space, apparently works well. I didn't want to contradict my friend, and so did some research and it transpires air conditioning units can be used as a heat pump. So... my question is, how does this stand with BC? Is it possible they didn't notice? Or took it on face value. Could it actually be working at 300-400% efficiency as ASHPs do...? I can't see that it could work with UFH? The inside unit had the appearance of a fugly, clumsy radiator , which is the only drawback... Anyone have any experience of this?
ProDave Posted October 30, 2020 Posted October 30, 2020 Yes they are one and the same. In this case it is an air to air heat pump. It takes heat out of the outside air, and blows that as warm air into the building. What we generically know as an "air source heat pump" is usually an Air to Water heat pump. they take heat out of the outside air and put that heat into water for use with under floor heating or radiators. In most cases both will do heating or cooling. 1
Jilly Posted October 30, 2020 Author Posted October 30, 2020 (edited) Thank you! That makes sense now. There sees to be a huge difference in price. Has anyone else used an air to air ASHP? Edited October 30, 2020 by Jilly grammar
Mr Punter Posted October 30, 2020 Posted October 30, 2020 I don't think that SAP is keen on air-to-air. 1
SteamyTea Posted October 30, 2020 Posted October 30, 2020 I am not sure about SAP, but seem to remember that there is no RHI on A2AHPs. This is because they are cheaper to start with. 1
